Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Budget Cut SBC Build Lots of parts what now?
Old 06-15-2012, 02:24 PM
High School Hot Rod High School Hot Rod is offline
Just when I have my build done on paper and my summit shopping cart finished my rent got jacked way due to the need for housing near the bakan oil fields. So my full roller 383 is a thing of the past.
Here is what I have:
383 short block scat crank 5.7 rods hyper pistons, ported 441 heads w/ hyd. flat springs good to .500 lift, weiand dual plane, trick flow 23 195cc w/ SR springs good for .650 lift, howards SR cam 247/249 .585/.585, stock 400 intake to oil pan bored 30 over never been reassembled.
The car is a 1980 camaro backed by a turbo 350, 3.90 gears, and 26in MT drag radials. Street car that will see the 1/8th mile.
What would you build Im thinking of building the 406, Im thinking I might change the springs in the trick flow's for solid ft and go that route with cheap 30 over pistons and the stock 400 rod and crank and selling the 383 with the 441's on top of it
thanks, again
