Well here it goes.. digging into another car and nothing knowing what's hiding beneath lol.. Well stripped lower quarter panel and someone has put a patch panel in, and seems like they took a grinder to remove the paint on the fender.... :nono: well here's my progress so far.. has anyone had good luck with repro fenders? or should I try to fix this one? I would have to skim coat the whole lower half?
and my first new addition to the body work family.. I love this thing already
reproduction panels don't fit well. you should put an inline regulator on that tool. you might wreck your piston with too much air. great for the doors but be careful over the wheels.
Nice progress. Can I make a suggestion in regards to your welding? Try to turn the wire speed down a little. You are getting way too much excess wire buildup that you end up grinding off. You should be able to get it where you have just a little hump to level off and not a mound. I would recommend some practice on some scrap pieces to get your settings right. You don't want to get too much heat into sheet metal as it will warp easily.
haven't had an update lately, so I got most of my patch panels done. I'm not happy with passenger side fender - door gap. So It looks like i'll be taking apart the front end again... for the 4th time :drunk: Picked up some rims and finally making progress.. here's some pics..
Damn that looks great. Your doing a great job. I did a resto on a 70RS once and I remember struggling with the drivers door gap and the rear quarters.. They do look nice when there done..
well that's not as bad as I was expecting.. a little Por and sanding will fix the problem.. then I will primer over the top with high build primer and paint to match the car.
Well got another coat on the car, but it's getting a little cold now. The paint was a little thicker from the cold than I liked. Over all looks pretty good, now I get to block the whole thing again. yay for me! Engine is coming out next week, so I can get the firewall ready
ok, so what do you guys think... Since I painted my falcon I still have some red and black left over (enough to do my jambs and under the hood) I photochopped the rims black to get a good idea what it would look like.
if you take a set of el-cheapo calipers from HF and scribe that fender you can grind the gap perfectly to match the door. either way it's a major improvement from the repop.
I've painted all the other cars right there in the garage. Didn't have much ventilation other than the side door. (pretty foggy) I'm running a big ol craftsman compressor. The only problem I really have is lighting. If I paint this one in the garage I'm going to add a few more lights. As for paint guns I have a hlpv "husky" gun. About a 70$ gun.. nothing special.
All my paints and clears have been from the "restoration shop" I have had pretty good luck with everything I have bought there. This is my 6th car I have painted. All of them have came out really well. All self taught and some trial and error.
This time I might take it to my buddies paint booth (since he finally cleaned it out) I might also try the "SPI" clear as well.
pulled the motor and trans.. time to get some color on the engine bay and engine.
Related Threads
Hot Rod Forum
2.2M posts
175.7K members
Since 2001
