Budget Rod Pics - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-19-2006, 02:42 PM
JunkyardTurbos.com
Budget Rod Pics
I'm building a hotrod project on a budget. I've got the ladder frame done, and I've just finished the rear suspension. I used control arms from a Jeep Rubicon to build the 4-link. The rear-end is a GM 12-bolt truck that I salvaged from an abandoned C/10. I have a Mexican block 302 w/351 heads and a C4 bolted to the frame. I plan to finish the whole thing for about $5K. I hope to have it weigh in at just under 2K lbs.
Old 06-25-2006, 10:13 AM
As a Moderator here ... I suggest you start a project journal here ... it is easy to do ... I have one ...Look over on my reply in the upper right corner and you will see Deuce's Project Journal and click on it ... or just click here ...
http://www.hotrodders.com/forum/jour...ge=1&reverse=1
You can display your progress as you go ... and share ...
Old 06-25-2006, 10:38 AM
JunkyardTurbos.com
I will do that. Thank you for the link!
SBC Destroked Destroked_SBC Engine 46 02-19-2006 12:43 AM
removing rod end with metal dust cover/spacer cboy Suspension - Brakes - Steering 3 01-24-2006 03:45 PM
5.7" vs. 6" savman1 Engine 30 01-20-2006 09:17 PM
327 in 88 Truck pete379 Engine 101 01-19-2006 09:03 PM
Rod Length Confusion, Short or Long??? Warrant Engine 11 01-12-2006 02:30 PM
