Im looking around for a budget urethane clear to be sprayed over PPG Deltron 2000 DBC.
I have searched on-line for hours now and have found a few clear coats that fit my budget and requirements for the Deltron DBC. Below is a list of the clear coats, If you have any info or experience with them please let me know.
If You can recommend another brand of budget urethane clear im open to suggestions.
1:
Finish-1 FC720, HS Urethane clear. (sherwin-williams brand)
DATA Sheet:
http://www.sherwin-automotive.com/me...ish/AS2818.pdf
2:
Nason Select-clear 460-00 Urethane. (DuPont budget brand)
DATA Sheet:
http://pc.dupont.com/dpc/en/US/html/...son/460-00.pdf
3:
Matrix-System MS-52 urethane. (
www.matrixsystem.com)
DATA Sheet:
http://www.matrixsystem.com/docs/tec...tech_sheet.pdf
4:
Kustom-Shop KC-210 Urethane 2K speed clear. (TCPGlobal.com big on ebay)
DATA sheet:
http://www.tcpglobal.com/kustomshop/...0606KC210P.pdf
What do you know about the clears listed above? If anything Please let me know.
If you know of a good budget urethane clear, Im open to all suggestions! Im not looking for Detron + quality clear at this time. If the deltron base sprays as good as everyone keeps saying, I will be asking about the clear latter down the road. But for now please just comment on the clears listed above, or other "Budget"clear coats that will work with Deltron DBC Thanks for your time!
