Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Budget urethane clears, Finish-1,Nason,Matrix, & Kustom-shop Any info?
Old 12-02-2009, 12:44 PM
smithkustoms's Avatar
smithkustoms smithkustoms is offline
Chroma-clear is is about $230 total, I use dupont chroma-base and clear a lot, I was told by my supplier that chroma-clear would not work over the Deltron DBC, Reasons unknown. I did not question his opinion. Never needed to.
Ive also used the nason select clear quite a bit and good results with it, My question was more or less a trick question to see how the other clear rate to the nason. At this point im still unsure if the nason clear will work with the Deltron DBC or I would just eb using it. The other three mentioned are the only clear coats I can find on-line that mention Deltron DBC in their tech sheet as a suitable basecoat. Not saying the other wont work, But it makes me feel better it see it listed.
Does anyone have a link to this SPI clear?
