Budget vortec build - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 02-27-2013, 12:53 AM
erauqssidlroweht
Midnight sun eh? Alaska was. Nice till I saw a mosquito stip a Kodak to the bones. The goal is 350hp with 1000 or less. I also forgot to mention the wrapped headers an flowmasters I have sitting around next to my miller welder.. Looking more and more like closer to 1000$ as I shop. Who knows, maybe the Pomona swap meet will have some good deals for me.
  #17 (permalink)
Old 02-27-2013, 01:05 AM
erauqssidlroweht
Aleady have the intake carb combo I want. Just need to shop for the cam, not looking to break 6000 rpms here gents, just a nice budget platform. I can add roller lifter cam later with a good blueprint and lightweight crank etc later.
  #18 (permalink)
Old 02-28-2013, 10:41 PM
erauqssidlroweht
Pomona swap meet
Ok, so I'm going to the Pomona Swap Meet to seek bargains on go fast parts, maybe I can get the budget lower than projected. I still need to rebuild my holley, or buy a rebuilt one. would love to slap my predator carb on it, but I promised my buddy he could use it for his 450 horse 11/1 v-belt 350 sbc engine. I figure he could use it more than me anyway. I would love to run into another one like that one, I only paid 150$ for it. "BTW: crackheads are great people"
  #19 (permalink)
Old 02-28-2013, 10:45 PM
erauqssidlroweht
what to put the engine into?
ok, so the topic for today is, What vehicle to drop it into? I want to put it into the 54' plymouth savoy, or my 75 scottsdale longbed. the plymouth would be trick with a floor shifted powerglide, but the truck would be easier, and already has poly engine and tranny mounts "no fab needed for engine and tranny, as well as steering modifications" does anyone know where to get a kit for this? I think I'll wander over to the HAMB, but I'm not looking forward to being called a sacrilegious whore and boo'd off the forum.
  #20 (permalink)
Old 03-02-2013, 12:52 AM
erauqssidlroweht
Found a set of ported vortecs for 125 but they need studs. Will std gen 1 studs work or are they specific? I am going to use my buddies valve machine and grind them myself. What angle/s should I use? Then Lapp them in place with a drill. All done. I'm also curious on the valvetrain std gen one rockers. Pushrods etc? Or do I need a different size/spec?
  #21 (permalink)
Old 03-02-2013, 10:37 AM
Proud LOSER
Originally Posted by gearheadslife View Post
hyper pistons alone are 200 bones,,
a mast kit with rebuilder cast pistons maybe
I just bought summits kit last month, its KB hypers
2 bills
The Following User Says Thank You to bygddy For This Useful Post:
NintendoKD (03-05-2013)
  #22 (permalink)
Old 03-02-2013, 10:39 AM
Proud LOSER
Originally Posted by NintendoKD View Post
Does it have to be isky? Don't get me wrong, good people, great work. I am looking at street strip/avenger cam combos, 1 because I need lifters anyway, 2 cheap setups, cheaper than buying individually. Gotta keep it in budget. Looking to stay under 126. Keep it coming.
Look at summits price on the Lunati barebones line. I haven't checked since the fall but my cam and lifters was 100$.
  #23 (permalink)
Old 03-04-2013, 04:38 PM
erauqssidlroweht
final pricing
got some news from the machinist today. Cyl cleared at .030 so I ordered the rebuild kit, dual roller timing set, oil pump drive shaft "for high volume pumps" cam and lifter combo got it all for 369.60. The machine work was 360 up front. that puts us at $729.60 add 250 or so for a set of heads and some rockers for the vortec heads, if it comes to that. plus $50 or so for nickel and dime and we are over the 1000 mark, but, very good price for a 350 horse setup. In fact, I don't think that there is a 350 horse combo out there that can compete with that price as a crate motor. summit has some listed for 330 hp at just shy of 3 grand: chevy performance 19210007, 8 or 9 for turnkey emgines. I have everything needed to have a turnkey engine at my fingertips.
cam was sum-k1105 298/304 466/487
moroso 22070 pump shaft
cloytes gear c-3023x
rebuild kit: sum-sbckit1-300
got the guy to givethe discounted price because it was so close to the beginning of the month. looking forward to this build.
I think I'm going to the pickn pull to find some valve covers and rockers from a low mileage vortec. go cheap, rockers are cheap to replace.
  #24 (permalink)
Old 03-04-2013, 04:45 PM
erauqssidlroweht
cheap crates?
CHEVY CRATE ENGINE - 350 HP - POWER-PRO ENGINES
this ones close to 3k with no turnkey and freight and core charge. I should get into this buisness. I could get used to making a grand off of each engine I build. build for 1500, sell for 2500 and undercut the competition. I get free 350 cores all day long. LOL
I think next I want to go for a super low compression 305 and turbothe ever living crap out of it.
  #25 (permalink)
Old 03-04-2013, 10:50 PM
erauqssidlroweht
thin gaskets
Just a quick question, can I use thin gaskets to get a little more compression on this engine? what 10$ a pair for shim gaskets so 20 bones for a couple of horsepower. am I getting too crazy here? I could ask the machinist to remove meat from the head surface but that is big bucks conpared to gaskets. the way I see it all other things being equal if the head gaskets are thinner there is less surface area to vent compression into other areas. right? what did 305 vortec heads come in maybe I can find and build some 305 high comp heads for cheap and clean them up myself.
  #26 (permalink)
Old 03-05-2013, 01:52 AM
erauqssidlroweht
Originally Posted by vinniekq2 View Post
I think wolverine and elgin are cheap names in cams
68,he said 350 ish hp and less than dirt cheap
I would buy used intake and carb for cheapo.
not a cheap cam
I tried to closely stick to what I have with stall speed in my converter with the HP target I had in mind. Balancing all that with the useable powerband I would get from the combo I'm using is quite fun in deed. I would normally agree with you, I don't like "cheap" as you tend to get what you pay for, but summit has a great return policy and excellent customer service. I'm doing a budget build so 89 buckaroonies it is. thanks though
  #27 (permalink)
Old 03-05-2013, 01:55 AM
erauqssidlroweht
I did, looked pretty good, the magnum cam seemed pretty nice, but I ended up getting the summit special dual profile cam. I bought a mother thumpr before and the lope is kinda cool, I have to admit, but that is my fun track all out engine, this is my around town rubber roasting engine, I don't want people getting too suspicious.
  #28 (permalink)
Old 03-06-2013, 04:56 AM
erauqssidlroweht
turnkey crates
looking at crate engines online, these guys have some of the cheapest prices I have ever seen. Not only can I not believe my eyes, I have to wonder how they keep costs down. This build was cheap physically because I had stuff lying around the garage. Block, intake, harmonic balancer, flexplate, coolant neck, hoses, distributor, etc. you know, the nickel and dime stuff that adds up to make a good engine a turn key one. The prices this guy shows are outrageously low for being 350hp combos. I looked twice at this comment, and I quote: "you will not need a stall speed converter" sounds almost too good to be true
well here is the website info:
Chevy 350 - 350HP Midnight Blue Crate Engines
  #29 (permalink)
Old 03-10-2013, 10:42 AM
erauqssidlroweht
final stage of the build
I got the block back from the machinist, preparing for final stage of engine rebuilding. I started soaking my lifters lat night, and cleaning the pushrods, preparing for inspection. I also started installing all of the rings into the pistons. I cleaned "blue shop towels" all of the mains and installed the crank to check the final clearances for oil with plastigauge. I also taped off the block and painted the block, oil pan, and cam cover black, to match the heads, the water pump is also black.
Budget 350 vortec swap Stormtrooper Engine 2 05-17-2012 06:10 AM
New Engine Build (Budget) weshova Engine 9 01-04-2010 07:38 PM
Budget PC build... ChevelleSS_LS6 Off-Topic 0 09-22-2009 02:16 PM
Help With Budget 350 Build Sparx74 Engine 22 09-23-2007 11:30 AM
what are some budget build ideas ? spinn Engine 1 04-04-2007 01:29 AM
