Buffing - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-13-2008, 06:16 PM
Buffing
How much do you guys normally charge to buff a suv ? The color is maroon (2003 ) light scratches and swirls ( no wetsanding ) . Approx. 4-6 hrs work ? Any advice appreciated, Thanks.
Old 02-14-2008, 05:28 PM
The only time I wet sand a car is to get out runs in the clear or smooth out orange peel in the clear. Wet sanding it now will not really get you the results you want. To get ride of the scratches you can buff those out with a compound and there also have a swirl remover that you can use. It can be used like a wax or buffed. You could probably find both of those at you local parts store and do it your self.
Old 02-16-2008, 10:25 PM
Last journal entry: Several Car Projects
Buffing
Estimate a total time and go based on an per hour basis and then add material cost (plus any up charge). Are you going down to a wool pad and Rubbing Compound, and then step back through with a foam pad and Swirl Mark Remover and finish with 3M Ultrafina SE. A quart of each of those will set you back about $30 to $70.
I am reffering to the 3M buffing sequence, see my earlier post.
buffing fresh paint, buffing old paint help!! prjavelin Body - Exterior 5 06-06-2007 07:33 AM
First time buffing Ratchet Body - Exterior 5 11-15-2006 04:51 PM
Buffing duallybuster Body - Exterior 0 07-28-2006 02:29 AM
Help me out here guys...Buffing Q's TurboS10 Body - Exterior 15 12-28-2002 04:33 PM
Clear Coat Sanding and Buffing Q's TurboS10 Body - Exterior 0 12-15-2002 08:28 AM
