that doesnt make any sense. i'm comparing hand sanding versus d/a when sanding clearcoat. using a d/a rather than wet sanding by hand will leave circular marks rather than straight marks. im not talking about removing swirls that polishers leave. sorry for any misunderstanding.
Also do wet sand...depends on the time I have and how good the clear is. Both ways I have never had a problem. This is my trunk lid |
ive never heard of polishing with a DA before, ill have to give it a try. i use the buffer with a waffle pad, then pending on the color ill do 3M imperial hand glaze. perfect everytime for me as well. everybody has their ways i guess. i always did wet sanding by hand until the explanation of the circular motion was explained to me about 4 years aog. now thats all i use when i work with a freshly cleared peice. im trying to get out of detailing all together. ive done it on the side for years and can't seem to get rid of it. im a marine electrician now and have some hotrod electrical jobs lined up already. but anyway.
new wave buffing
hi,from sparkys,just color sanded a 32 glass coupe painted with single stage concept ppg.used 3-ms newest,first wet sanded with 1500,then used adapter on da with 3000 wet,then buffed with wool yes wool pad.after that applied new glaze with foam pad,looked good,then used 3-m supplied rags wiped off excess glaze,paint looks 3 feet deep and you can see your wiskers in reflection,to beat it all this color is vette milinium yellow. thanks randy sparks sparkysrodshop.if you want 3-ms numbers and names call me 423-505-4144
Millenium yellow is a 3 step paint, base, tint, clear. You said single stage....did you not use the tint coat? Just curious and wondered if it would be brighter with out the tunt coat |
60% price increase!
| First time buffing | Ratchet | Body - Exterior | 5 | 11-15-2006 03:51 PM |
| Vega box - adjustment advice please? | Limey Simon | Suspension - Brakes - Steering | 3 | 07-23-2005 05:09 PM |
| advice on where to learn? | DC8808 | Hotrodders' Lounge | 6 | 05-26-2005 04:28 PM |
| Help me out here guys...Buffing Q's | TurboS10 | Body - Exterior | 15 | 12-28-2002 03:33 PM |
| Clear Coat Sanding and Buffing Q's | TurboS10 | Body - Exterior | 0 | 12-15-2002 07:28 AM |
