Buggmann In Need Of Help - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-07-2008, 04:03 PM
buggmann's Avatar
build it like you like them
Last journal entry: buggmann stilling looking
Wiki Edits: 2
I NEED TO TAKE OFF THE HARMONIC BALANCER
OFF MY 1953 CHEVY 210 STRIGHT 6
I NEED TO FIX THE TIMEING CHAIN COVER
ANY HELP THANKS BUGGMANN
Old 09-07-2008, 04:10 PM
A normal ballancer puller won't do it?
Old 09-07-2008, 04:13 PM
buggmann's Avatar
Wiki Edits: 2
Buggmann
OK SO HOW DO I GET IT OFF
AND WHAT TO USE
Old 09-07-2008, 04:31 PM
malc's Avatar
Living At The Speed Of Life
One of these will do the trick.
How to use it.
BTW, STOP SHOUTING.
Edit: Sorry it seems the instructions are´nt instructions just a parts list, but it does say instructions included.
Old 09-07-2008, 05:49 PM
37 plymouth coupe's Avatar
buggmann in need of help
Am I wrong, or didn't the inline 6's in those days have a gear drive instead of a chain and it required removing the camshaft and pressing the timing gear off? You may need more than just a harmonic balancer puller.
Somebody jump in here and correct me if I am wrong.
Old 09-07-2008, 06:25 PM
Wiki Edits: 31
you use just a standard harmonic dampener puller.. you thread the bolts into the dampener, and crank it down.. it is not bolted on, just pressed..
and yes, the timing set is a gear drive
need brake help buggmann buggmann Suspension - Brakes - Steering 5 06-05-2008 11:01 PM
buggmann buggmann Hotrodders' Lounge 11 05-13-2008 11:33 AM
buggmann buggmann Engine 8 04-27-2008 03:56 PM
buggmann buggmann Hotrodding Basics 1 10-26-2007 08:41 PM
buggmann buggmann Engine 1 10-24-2007 08:17 AM
