buggmann needs help - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-12-2009, 10:27 PM
buggmann's Avatar
build it like you like them
Last journal entry: buggmann stilling looking
Wiki Edits: 2
buggmann needs help
the brake peddle on my 1953 Chevy
went hard and now i cant get it to move
what would make it do that
we just rebuilt the hole system
on the car
any help
thanks buggmann
Old 02-13-2009, 12:59 AM
SSedan64's Avatar
Priapisum, Buddy dropped some Viagra in the reservoir.
Sounds like something is in a bind, Brake peddle, master cylinder rod adjusted out to far causing piston to bind. Maybe?
Old 02-13-2009, 05:55 AM
pepi's Avatar
Last wiki edit: Determining top dead center
Last journal entry: Quicky frame dolly
did not specify power or manual, if power and just hard check booster, manual or power and pedal jammed sounds like a mechanical bind like mention above ..
Old 02-13-2009, 08:14 AM
buggmann's Avatar
Wiki Edits: 2
buggmanns 1953 chevy
no power
went to bleed them
it was OK got done
went to try them out and that is when it hap pend
Old 02-13-2009, 04:58 PM
buggmann's Avatar
Wiki Edits: 2
hey we found the prob
the bolt that holds the
peddle to the arm that comes off the
master cylinder was in a bind with a shift rod
buggmann needs help loading pics buggmann Hotrodders Site Suggestions and Help 9 04-28-2009 04:59 PM
Buggmann In Need Of Help buggmann Engine 5 09-07-2008 05:25 PM
need brake help buggmann buggmann Suspension - Brakes - Steering 5 06-05-2008 10:01 PM
buggmann buggmann Engine 8 04-27-2008 02:56 PM
buggmann buggmann Engine 1 10-24-2007 07:17 AM
