buggmann needs help with sandblasting - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-31-2009, 07:19 PM
buggmann's Avatar
build it like you like them
Last journal entry: buggmann stilling looking
Wiki Edits: 2
i found a sandblaster on craigslist in ga
it was 50.00 cash so i got it and will
pick it up in a day or two
but i need to find out what kind of sand to use
and how big of a air compressor i will need as is i have
a 11 gal and a 30 gal compressor i want to know
if they will work or will i need a bigger one i want to use
the blaster on my 1953 chevy 210 so i can save some money
and do it all my self
any help let me know thanks buggmann
Old 03-31-2009, 08:27 PM
schnitz's Avatar
Last wiki edit: Building a new shop
Last journal entry: Christmas 2008 came early!!!
Wiki Edits: 54
Use very fine sandblasting sand, as regular beach sand hasn't worked in any blaster I've ever been around. IIRC, it's around $3-6 a 50lb bag. Second bit, I would recommend NOT using it for sheet metal blasting as the heat generated can badly warp body panels or even "blow thru" some already rusted areas. Third, I'd make dang sure if it's a pressurized unit that the tank is in good shape and the safety related items are in good working order. Basically, use common sense while using it.
As far as air goes, pay no attention to compressor HP ratings, look towards the CFM ratings. But, be forewarned, sandblasters will hog out on air worse than any D.A. sander I've ever heard of. A buddy of mine worked in a ready-mix plant, and the industrial unit they had barely could keep up.
In a while, Chet.
Old 03-31-2009, 08:30 PM
Your compressor may do ok. You might have to do a section and stop to let it build pressure. My advice would be to Not use sand. It can warp panels. Go with a plastic media. Check with a body shop supplier or Easwood Co. carries it
Old 03-31-2009, 08:35 PM
schnitz's Avatar
Wiki Edits: 54
Dang, you beat me to the edit I was going to make after seeing this thread....
He's right, and I stand corrected DO NOT use sand. Clean body panels are not worth losing your lungs. Oldred will hopefully have more info on this. But, I still do stand by my advice about not using it on body panels for the reasons I stated before-- unless those other media methods are easier on heat warp and destruction.
In a while, Chet.
Old 03-31-2009, 08:41 PM
Don' forget to wear a dustmask and goggles no matter what media you use
Old 04-03-2009, 12:06 PM
Eschew Cowards
FIRST, do a complete inspection of the blaster to determine if it's even safe to fart into.
Then:
Determine what you actually have as a compressor. Gallons have absolutely no meaning in compressed air.
Clean out the vessel completely. More time is wasted in blasting due to plugged valves from cigarett buts and chewing gum than any other problem.
Get and install a proper sized tip
Install a sufficient siameter hose between the air line and the blaster.
Fill blaster vessel with a strainer. No kidding, it helps a lot.
Place head into appropriate protective equipment
Begin blasting. 30 to 45 seconds later begin wondering why you thought this was a good idea.
You really think you're going to save money running a blaster?
Old 04-04-2009, 08:39 AM
Wiki Edits: 27
wet blaster
I bought a wet blaster from northern tool to use with my 4000 psi presure washer we use to clean the farm equipment and concrete forms. . I ran a bucket of sand thru it to test it. IT MAKES A MESS . wet sand everywhere but NO dust. It did a pretty good job of removing rust from some scrap iron pieces. I have a 5 hp upright shop compressor , 50 gal tank and it won't keep up with the small sears 5 gallon bucket sandblaster.
Old 04-04-2009, 02:03 PM
Eschew Cowards
Bucket fed blasters-
Way back in ancient times I sat in a classroom and learned of a thing called work. It's really a simple concept, convert energy into productive results.
Someplace in time since, work seems to have become a dirty 4 letter word not used in polite society.
The thing about bucket fed blasters is that much if not most of the work involved with the mechanism is wasted when it could be made productive. Since compressed air is the most expensive form of energy, I don't like wasting it, and since I'm naturally lazy I hate wasting work.
ELEVATE THE FRIGGIN BUCKET!
By placing the bucket delivering the media to the blaststream you eliminate nearly all the work involved getting the media to the tip. That's about 7˘ of every dime you spend blasting, and 6˘ of that can be converted to productive work by making a simple change to the operation.
No it didn't take NASA engineers to figure this out, they were busy consuming taxpayer dollars holding a meeting on toilet paper.
Old 04-08-2009, 03:36 PM
deadbodyman's Avatar
Wiki Edits: 11
Whats up Franz? I Only checked in cause I needed a laugh and I knew you could do it and I was right.BTW all the guys at the shop loved your story about painting the barn just thought you'd like to know.
Cutting glass by sandblasting, Urban Myth? MARTINSR Body - Exterior 61 01-03-2015 08:48 PM
sandblasting vs air pollution csrao222 General Rodding Tech 15 10-18-2008 09:31 PM
Sandblasting Booth stinger12 Garage - Tools 21 04-09-2007 06:45 AM
Sandblasting rims question ChrisMiddleron Body - Exterior 7 02-07-2005 10:27 AM
Sandblasting question ChrisMiddleron Body - Exterior 6 12-27-2003 12:50 PM
