Buick 231 torque converter - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-24-2008, 05:34 PM
Hi,I"m trying to find the right torque converter for my 85 Buick regal V6.I don't know if it's 10' or 12'.What should I be looking for.Do I get 2000 stall or 2500stall or what?? IT's only going to be for street use and with lockup to improve mileage.Does anyone know?
Old 02-24-2008, 08:55 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
give us a clue to what transmission you are using.
What is the car used for? You mention street only... a daily driver?
Is the engine built up or stock?
Do you have the trans out now? Why?
Does the trans need a rebuild too?
Old 02-25-2008, 08:55 PM
Hi I pretty sure it's a hydra-matic 200 or 250.I want the car to be a weekend driver enough power to burn some rubber if I wanted too.The 3.8 v6 has a bigger cam and new intake with a 4 bbl carb instead of a 2bbl.I also put headers in.Long story short the motor is seized and since I'm changing the pistons now with the rebuild I wanted to spruce up the rear end.Does that sound OK?
Old 02-25-2008, 08:59 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
Better figure out which transmission you have.... the t-200, t-200C and t-250C require different converter design.
have fun.
Torque Converter Question newbielike Transmission - Rearend 2 12-17-2007 06:53 PM
Torque converter question sam83k10 Transmission - Rearend 7 08-09-2007 08:23 PM
Chevy Torque Converter Swap! leejoy Transmission - Rearend 7 01-04-2007 06:55 AM
Building a SBC to rev to 8k, and have power Andyrew Engine 52 04-17-2006 01:46 PM
torque converter IDENTIFICATION 327amc Transmission - Rearend 5 03-26-2005 07:23 PM
