Buick 3.8 turbo Q:
Greetings, requesting some input on a build. I am rebuilding a 1979 Buick 231 even fire V6. It has the factory carburator draw through turbo setup, Rochester carb. This will have .030 overbore, stock dished type pistons. I would like to end up with a mild engine, little more power but still drivable and reliable. Any buick Guru's with cam type/specs that would work nicely. Vehicle is a modded 40 dodge truck, T350 trans and ford 9 rear with 3:50 gears. Weight is right at 2870 LB's. Any suggestions on a cam that will work good. *On the draw through Turbocharger set up I can't run a intercooler.
Ken Duttweiler is well known for his work in Buick's.On this one I am out of the loop.I tired to find a web site/link to him and couldn't find one.Maybe someone else will chime in with that.
ya ya send him for a fwd engine.. the 3800 in the f body was never s/c the s/c type II aand III are front drive blocks. to the o/p I'd hit up turbobuick.com and look around/ask there.. |
The Series II/III blocks are the same for FWD and RWD. They all use the 60 degree metric bellhousing (same as the Chevy 2.8 V6 family). The 3800 SC has been swapped into MANY, MANY RWD cars with no problems. Simply use the 60 degree trans bellhousing from a 3rd or 4th gen F-body or an S-10. This is easy. The Turbo Buick crowd has even discovered the Series II motor as a nice replacement for the GN motors, again using the correct bellhousing.
ya, if you want to change out the whole drivetrain.. |
If you have a choice the grand national efi system works well and supports a lot of hp.
For cams You may want to see what buick used in the gnx it was more hp in factory form than all the other buicks. Last year had the best cam. I think you can have this cam ground if its not off the shelf. The gm typhoon and cyclone also have a very nice v6 turbo system. Its pretty amazing. I would save you from the carb turbo experience. You will spend twp years plaipying with it only to rip the entire system down and install a proper efi turbo setup that will make an easy 350hp. Without blowing the motor or having to adjust the carb that is boost referecenced. best to getit right the first time thru. Fyi you can also hit the 500 hp mark with a gnx and still be drivable with minor updates. That should cover the trucks life no matter how you decide to use it. Also will get alot more mpg. The carb setups are just blowing fuel at high boost levels. A carb box is a much better way to go carb. Draw thru is good for drag car and a lot of drag bikes run it. But for the street its never going to be in perfect tune. Works awesome with methonal. Its a lot of work to go efi and turbo all at once but its the best way to go. It will start up and run in cold and hot weather and never complain when you punch it. Since its a big truck this will live in the boost. Intercooler will also make crappy pump gas give up some more boost without knocking. If you go efi one of the ford trucks has a giant intercooler that works great and should fit in front of the radiator with some new brackets. Hope this helps |
Buick Turbo
I wish it was the later EFI 3.8, but I'll be using what I already have. It's not a daily driver but I know with the draw through turbo, cam selection is critical. I was asking if anyone had any experience with this set up and what they used. I already have the short block ready but I was wondering if there is a mild cam that might work better than the stock setup.
IIRC the 2.8 the 3.1 the 3.4 are 60* v6 the 3300 &3800 are 90* v6's and not even anywhere near the 2,8 engine family.. |
The supercharged 3800 is the one I was referring to as having many advantages, in fact if money is tight I'd probably just get one of these engines in good condition, adapt a turbo kit, and swap the trans or bellhousing. Down the road you can work on the heads and swap the cam. |
sounds like the elcheapo way to me <rolls eyes> |
| Turbo- Buick Nailhead | fast70gs | Engine | 3 | 06-15-2008 11:20 PM |
| Turbo- Buick Nailhead | fast70gs | Introduce Yourself | 2 | 06-13-2008 09:16 AM |
| 3.8 buick turbo | dennisd30 | Engine | 8 | 02-20-2008 09:15 AM |
| Turbo V6 Buick | dirt t | Engine | 2 | 03-12-2007 03:59 AM |
| buick 350 turbo | chevycheyennetruck | Transmission - Rearend | 8 | 03-05-2007 04:27 PM |
