buick 350 2 bbl carb - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-05-2011, 12:42 AM
How much horsepower does a1973 buick apollo have with a buick 350 2bbl carb
Old 08-05-2011, 06:28 AM
helrazr3's Avatar
im on a highway to hell
Last journal entry: new wheels and seats
according to these folks http://www.musclecarclub.com/musclec...gs-specs.shtml about 150hp
Old 08-05-2011, 08:30 PM
How much does a buick 455 big block cost?
Old 08-05-2011, 08:47 PM
helrazr3's Avatar
you can probably get a used one for under a grand but the mid 70's motors didnt have much more hp than your 350 they were really whimped out.
Old 08-05-2011, 08:56 PM
I need a engine with at least 200 hp... do you know where I can get one for a 1973 buick apollo
Old 08-05-2011, 10:35 PM
helrazr3's Avatar
what are you trying to do? the rating for the 350 with a 4 bbl carb is 195 im sure with a basic intake and carb swap and maybe headers you can be over 200.
Old 08-05-2011, 10:40 PM
I'm trying to increase the horsepower on my 73 buick apollo
Old 08-05-2011, 10:47 PM
helrazr3's Avatar
are you taking it to the track or just cruzing around town? if your just looking to increase performance i would work on what you have. what do you have for a transmission?
Old 08-05-2011, 11:13 PM
400 turbo transmission
Old 08-05-2011, 11:28 PM
Thm400 transmission
Old 08-06-2011, 02:14 PM
helrazr3's Avatar
i would say new carb and intake, hei distributor, headers and exhaust if you really want to go this far a new cam and lifters. im not sure how available aftermarket parts are for a buick 350 that can also determine how far you go with upgrades. good luck it sounds like a nice project car.
Old 08-06-2011, 03:03 PM
Does this car need smog checks
Old 08-06-2011, 03:50 PM
helrazr3's Avatar
what state are you in? usually you wont need a smog check but in some states you need to have whatever pollution controls that came with the car on it. like an air pump or a catalytic converter
Old 08-06-2011, 04:33 PM
I live in california
Old 08-07-2011, 07:51 AM
LATECH's Avatar
Last journal entry: New Gas Tank
Maybe you should chunk in a Lunati 33202 cam and put a quadrajet on top, then dual exhaust for sound and performance.
Those 3 mods should boost you up where you are looking to go.
Your big problem is partly compression ratio.Put in the cam and advance it some after degreeing it so you benefit the dynamic compression ratio a little more, helping your low end power.Tweeking the dizzy would be a definite plus too. I dont run buick but I amsure you could get the info on the dizzyyou need here somewhere.
these would be the three easiest things to do for more performance, otherwise its time to tear your motor down and do some mods.
1958 buick onto 1993 buick frame/floor flatlandlowrider General Rodding Tech 5 03-27-2011 07:17 PM
What metering jets are found in a stock 1980 M2MC carb on a buick Killhard Engine 0 12-05-2010 06:58 PM
Edelbrock Carb Size for Stock Buick 455 youngceez Engine 38 03-05-2010 09:54 AM
buick 350 carb wranglr88 Engine 2 05-10-2007 12:08 AM
Buick stumbles after carb work JUSTINH Engine 2 03-18-2003 08:02 AM
