buick 350 - chevy 350 - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-23-2007, 10:40 PM
i have been looking around on this cite for a while and there is a lot of great info in here but the one thing i haven't found is the difference between a Buick 350 and a Chevy 350. i know they are built alot different but are the specs the same as in hp and torque ? i have a 72 Buick skylark with the 350 but i also have a Chevy 350 sitting around so i was wondering if i should build up the Buick 350 or transplant the Chevy in to it and build it up. both engine are stock. if you guys could give me a push in the right direction i would be thankful.
Old 04-23-2007, 11:03 PM
ericnova72's Avatar
More for Less Racer
buick 350-chevy 350
Heard a noise........sounds like a can of worms is being opened!?! Put that belly-button engine in and you'll never hear the end of it from the Buick guys. Look up T.A. Performance on the web. It justs costs a little more to do a "Gentilmans hot-rod" is all. Stay all Buick and you'll be happier in the end.
Old 04-23-2007, 11:06 PM
Banned
THe Buick has a different bellhousing pattern than the Chevy- so youll need an adaptor or a different tranny. I would instead just swap the motor mounts and build a Pontiac 400 or an Olds 350- either is better than a Buick 350 (also known as the worst 350 made). You can get any of these engines from a salvage yard for a few hundred, which in comparison to an engine build is pocket change.
Old 04-23-2007, 11:21 PM
Blazin72's Avatar
You got a leaky spark tube...
Last wiki edit: Rearend removal
Last journal entry: General Lee
Wiki Edits: 19
Keep your Buick all Buick man. A buddy at work has a Skylark running low 13s with a Buick 350. If you want more power then track down a Buick 455.
Old 04-24-2007, 08:31 AM
Hippie's Avatar
Last journal entry: HEI comparison.
Keep the Buford ALL Buford! Buick 350's are more expensive to build for sure and they need a little more attention to details to make them survive but they can be decent performers and the cool factor is off the chart!
"Worst" 350? Never heard that but "worst" is all a matter of perspective. My kid had one in one of his demo cars, ran it out of water, low on oil and caught it on fire. Went out the next day and it fired right up. A friend of his ran it in two more demos after that. This was an engine that had clearly not had regular maintenance and had 100,000 miles on it.
Old 04-24-2007, 10:28 AM
Banned
I say worst because of the power potential with stock heads... pretty much nonexistant.
Old 04-29-2007, 08:15 PM
Bald Menace's Avatar
YUP.. it's a Buick
Last journal entry: the car was completed and looks great
I know of a Buick 350 with ported stock iron heads that pulled 1100 horsepower on the dyno. a set of buick 350 heads can be ported to flow 270-290 cfm on the intake side and 190-200 on the exhaust side. thats enough to make one screamin 350 engine. one of our club member ashas a buick 350 that is naturally aspirated and makes nearly 600 hp.one thing we Buick guys love is the lack of info out there about Buick power and potential. the look on a guys face when he gets his doors blown off by a Buick that looks stock is worth every extra dollar we had to spend. also a Buick 350 engine weighs 100 lbs less than a similarly equipped chevy 350
Old 04-29-2007, 10:41 PM
135 mph
I had a 350 with a mild Schneider cam and a quadrajet and my 1970 Skylark convertible could bury the speedo.135? maybe more. I totally freaked out some guys in a 5.0 Mustang when I passed em doing 130... Good luck with the Buick and it is way lighter for sure. I still have the car but it now has a 396 in it.
Clint
Old 04-12-2008, 04:07 PM
fordisbetter's Avatar
you know a radical alternative is to build a 3.8v6 turbo engine like what came i n the grand nationals so that way you car will be all Buick still also the 3.8 is a vary stout engine 450 to 500hp is easily attainable
Old 03-12-2009, 10:14 AM
You can get as much power from a buick as you can a chevy but it is like this people put chevy engines in fords because it is cheaper to build it. They do the same thing with buicks. The only folks i know that don't go that route are the mopar guys. If you have the time and money then stick with the buick engine. I judge car shows in the summer and i will give a higher score to the guy who kept it all original than the guy who bastarized the hell out of a non race car so it would look "cool and shiny".
Old 03-12-2009, 11:04 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
The Buick 350 is a good, durable, pedestrian engine. Expensive to build, though. And limited by poor heads.
If it were me, I'd shop around for a Buick 455. Still expensive to build, but with 3.08's it'll run 13's all day with nothing more than a mild cam, intake and headers. And it'll smoke the tires into next freaking week!
If you want more, Edelbrock makes heads as does some of the Buick specialty shops.
Old 03-12-2009, 11:26 AM
I don't buy the cheaper to build argument. I think the real reason the world uses belly-button Chebby motors in everything is because you don't need to think. You just write a check and bolt the motor in.
Keep in mind that the reason every car magazine in the world runs a monthly SBC buildup article is to keep their advertisers happy. Show some spine and keep the Buford motor. I do agree that I'd go with a 455, however.
Old 03-12-2009, 11:49 PM
fast68's Avatar
likes chevy trucks & boobies
hi there
wow i still have not ever seen an actual buick 350 or any size v-8 engine IRL ever
seem to be extremely rare and long gone from existence
ive seen pics online and wow they look funny..
very alien.
if you go with chevy then youre gonna have to change everything,.,
exhaust, engine mounts and tranny and so on
good luck
Old 03-13-2009, 05:59 PM
buick 350 chevy 350
hey guys
i got good news i am going to upgrade. i bought a 72 455 motor and going to put that in there. haven't gotten around to taking it apart and was reading up on it. i am really worried about my block that it could be bad. cause of core shift. i am going to get it apart and send it in to get tested. but is that a big problem or should i just not worry about it?
Old 03-13-2009, 07:02 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
The short answer is: Don't sweat it, IMHO.
If the core shift was really bad, it wouldn't have made it out of the foundry.
This isn't to say that core shift isn't a consideration- it certainly can be, mostly with highly stressed apps. Core shift can cause problems w/valve train geometry and cylinder wall thickness, to name but two.
But in your case (I'm assuming a "street performance" build here) core shift is a consideration mainly if a 0.060" plus overbore is necessary.
Hopefully your block- if untouched up until now- will clean up @ 0.030". I've yet to see core shift effect a 30 over rebuild.
Were you able to see the engine run? In any event after the machinist mags the block and heads you will have a better idea of where you stand. I'd be more concerned with a cracked head or heaven forbid, block, than core shift.
BTW, I'm glad you chose this route. You're in for some kinda fun!
List all of your cars HERE! Carbed95GT Hotrodders' Lounge 289 11-09-2011 07:43 PM
Hi. just wondering why the 350 chevy small block is so good... judgedredd Hotrodders' Lounge 78 06-25-2010 09:01 AM
El Camino Engine - 350 Chevy or 455 Pontiac bjam2 Engine 16 08-07-2007 04:45 PM
El Camino Engine - 350 Chevy or 455 Pontiac bjam2 Engine 17 01-06-2007 10:11 PM
Will my Buick 350 (1970) fit into my 1984 Chevy K10? GFORCECONSTRUCTION Engine 0 05-22-2006 08:58 PM
