Buick 350 or Chevy 350 - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-26-2006, 07:09 PM
Hey Guys
I have the original Buick 350 in my skylark, but I can get a Chevy 350 4 bolt main for it.......for reasonably cheap, rebuilt from a shop for around $350....I already have a 400 Turbo tranny to go behind it... Buick 350 thats in it, or Chevy 350 4 bolt main?
Wil
Old 01-26-2006, 07:16 PM
Blazin72's Avatar
You got a leaky spark tube...
Last wiki edit: Rearend removal
Last journal entry: General Lee
Wiki Edits: 19
Keep the Buick all Buick man. It's going to be considerably more expensive than a Chevy but you can still get performance parts for the Buick V8s. Try www.taperformance.com
Old 01-26-2006, 07:18 PM
redlightning's Avatar
You could ask these guys.
http://v8buick.com/forumdisplay.php?f=8
Old 01-26-2006, 07:38 PM
poncho62's Avatar
Wiki Edits: 5
If that turbo 400 is bolted to the Buick motor now, it wont fit the Chevy block.
I would stick with the Buick too. They are a decent motor. Performance parts are expensive though.
Ontario Rodders
Old 01-27-2006, 08:35 AM
The only problem is.....
parts for the Buick 350 ARE expensive......Chevy 350, easy to come by.. Buick 350 needs a lot of work.....Chevy 350 good to go....400 tranny on a stand awaiting a Chevy block......or Buick has a meesely 200 tranny in it..
I am still stuck....i wanna be all original, but I drive this car every day and want it to be easy and cheap to work on too....
Wil
Old 01-27-2006, 10:51 AM
farna's Avatar
Last wiki edit: AMC V-8s Last photo:
Wiki Edits: 14
In that case get the rebuilt 350, just realize you need to buy a rebuilt or used tranny also. B/O/P used one bolt pattern bell housing, Chevy cars and Chevy/GM trucks another. Right now looks like it will cost about the same to swap in the new Chevy engine and trans as rebuilding the Buick, but having a stronger TH350 trans. I'd go ahead and get an OD trans while you're at it. At least future upgrades would be cheaper.
Old 01-27-2006, 10:55 AM
Don't forget you'll also need accessory brackets, possibly some rewiring. Is the Chevy engine ready to run or do you need an intake, distributor, exhaust, etc? Personally if it were mine I'd keep the Buick engine in there.
Old 01-27-2006, 11:01 AM
One Problem
i want to keep the Buick 350, but it doesn't run strong anymore.....I am wanting to put headers and side pipes on it.....but want it to run strong too....
Old 01-28-2006, 01:35 AM
Blazin72's Avatar
Wiki Edits: 19
Putting a Chevy in a Ford is one thing, but putting a Chevy in a Buick? That just aint right. Any hardcore Buick fan would be extremely disappointed if you lifted the hood only to reveal a Chevy. I still think you outta keep the Buick engine in it.
Old 01-28-2006, 08:40 AM
TooSlow's Avatar
Beater Driver
I had a '72 Skylark that I put a 350 Chevy into. All of the "Buick Faithful" will growl at you about it. If you care what other people think then you better stick to the Buick engine. If you couldn't care less what others think, then by all means go with the Chevy--it is much cheaper to make the 350 Chevy run hard.
TooSlow
Old 01-28-2006, 08:59 AM
Zimmo's Avatar
If you want power, there's no replacement for displacement. I would be on the look out for a Buick 455. Ebay has some good deals if you're not too far from the seller - you don't want to ship a $150 engine 3000 miles.
A mild rebuild on a 455 (stock everything except for intake, ignition, exhaust, cam & compression) would give you good power. You don't want to go crazy on aftermarket high-end stuff. Look for an beater car locally with a 455 and buy it cheap.
Old 01-30-2006, 03:00 PM
Eureka!!!
My dad and i have decided to rebuild the Buick 350 in it....starting on it next week...
Thanks for the help guys....
Old 01-30-2006, 03:56 PM
How fast is fast enough?
For power a buick 350 is about the worst engine to start with, however a buick 455 is a great big block. I would go 455- you'll thankyourself later.
Old 01-30-2006, 05:41 PM
TooSlow's Avatar
Beater Driver
Good luck with the rebuild!
Old 01-30-2006, 11:28 PM
Thanks!!
Thanks a lot...
I already got the gasket and bearings kit....$27!!!! American Gasket rocks!!!
Hi. just wondering why the 350 chevy small block is so good... judgedredd Hotrodders' Lounge 78 06-25-2010 08:01 AM
El Camino Engine - 350 Chevy or 455 Pontiac bjam2 Engine 16 08-07-2007 03:45 PM
El Camino Engine - 350 Chevy or 455 Pontiac bjam2 Engine 17 01-06-2007 09:11 PM
1978 grand prix chevy 350 swap threesand9s Engine 10 06-29-2004 12:43 PM
85 chevy 305 heads on an 89 TBI chevy 350? jazzguitar Engine 4 11-03-2002 04:11 AM
