buick 455 in a 87 cutlass supreme? - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-10-2012, 10:00 PM
hi i have a 1987 cutlass supreme that has the stock buick 3.8 in it and i have a friend that is going to drop a buick 455 in it from an old 73 riviera, to anyone that has done this befor, is there anything major that has to be changed or customized?
Old 06-12-2012, 12:17 AM
What transmission? In stock form its not going to hold up very long with the 455 in front of it.
Make sure you get a larger radiator.
What do youpplan to use for exhaust, manifolds or headers
Old 06-13-2012, 02:15 AM
im going with manifolds and custom micky mouse duel exhaust and the mufflers will dump just befor the rear axel and im gonna try to use the rad from the rivera and i do have the riviera's th400 tranny to go with the buick 455
but ill have to use the stock v6 rear end, becuz i cant afford a new rear atm, i should get by fine aslong i dont hotrod it around and lay rubber all over
right?
Old 06-13-2012, 01:09 PM
right?
As long as you dont beat on it the axle will hold for a while, but eventually, even with upgrades, the 7.5 will eventually break.
U may have fitment issues near the A/C housing on the fire wall. Most use a die grinder to cut a section of the housing out, then use fibeglass to make a cupped patch that gives better clearence.
cutlass supreme 81 Vick3607 Transmission - Rearend 4 04-04-2012 08:12 PM
what can I put in my 84 cutlass supreme 84cutty Engine 28 06-29-2010 09:21 AM
Cutlass Supreme????? greasemonkey92 Suspension - Brakes - Steering 9 11-06-2007 05:02 PM
Cutlass Supreme HP? greasemonkey92 Engine 1 01-13-2003 10:37 AM
305 Cutlass Supreme greasemonkey92 Engine 3 10-03-2002 08:50 PM
