Buick 455 with T350 - Hot Rod Forum : Hotrodders Bulletin Board
Hot Rod Forum : Hotrodders Bulletin Board > Tech Help> Transmission - Rearend
Old 07-02-2014, 11:03 PM
Buick 455 with T350
So I am building a 455 Buick that will be fairly mild, .030 over to clean up the cylinders, stock hyperutectic dish pistons. Heads miled and mild port job/near stock compression of 8.4:1. compcams 268, and a few oiling mods for reliability, stock stage 1 intake with a carter AFB 625.
I have a few BOP turbo 350's and also two Chevy bolt pattern turbo 400's that iI I could use with an adapter plate . Will a mild rebuilt T350 hold up to the torque of the buick. It's going in a street car. Should have about 380 horsepower and a little over 500 LB pounds of torque. Any Converter recommendation?. Running a 9" ford rear with a 350 gear posi.
    Advertisement
Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Old 07-02-2014, 11:38 PM
Duplicate, screwed up editing
Old 07-02-2014, 11:41 PM
30 years ago I had a 71 Cutlass with a 350 and a 350 tranny. When the tranny went out I installed a Neal Chance street strip 350 with a 10 bolt case. When I upgraded to a 455 engine I left the 350 tranny in it. The 455 also had a Comp 268 cam. Never had a problem with it. Cutlass sadley fell victim to a driver running a red light.
Old 07-02-2014, 11:55 PM
ericnova72's Avatar
Properly rebuilt with some simple clutch/sprag upgrades, and proper clearances, a 350 will have no problems.
Something in the 2400-2600 stall area would likely be good, but get it on an 10" converter core, 11" core second choice,... not a 12" bent fin stock core.
Old 07-19-2014, 08:47 AM
TexasT's Avatar
Did you ever wonder?
Last journal entry: A little follow up
As far as converter I'd go with something in the 1800-2200 rpm stall range. TH350 should be fine until you hit the track or bolt on some sticky tires.
What is a stock stage 1 intake? You will need more cfm. Big Buicks like plenty of carburation. In the later years they came with an 800fm Q-jet from the factory. Also you might look at some Lunati cam grinds.
400-430-455-Block-ID-Prep-and-Oiling-mods
Recent Transmission - Rearend posts with photos
Quick Reply
Message:
Options
Register Now
In order to be able to post messages on the Hot Rod Forum : Hotrodders Bulletin Board forums, you must first register.
Please enter your desired user name (usually not your first and last name), your email address and other required details in the form below.
User Name:
Please enter a password for your user account. Note that passwords are case-sensitive.
Password:
Confirm Password:
Email Address
Please enter a valid email address for yourself.
Email Address:
Insurance
Please select your insurance company (Optional)
Log-in
Human Verification
In order to verify that you are a human and not a spam bot, please enter the answer into the following box below based on the instructions contained in the graphic.
You may post new threads
You may post replies
73 Buick 455 Wildcat465 Engine 1 01-31-2012 04:41 PM
buick 455 and pontiac 455 valve covers rooster88 Engine 2 07-14-2011 07:50 PM
Buick 455 94chevy Engine 3 04-17-2006 03:56 PM
Buick 455 smuhammad Engine 5 01-07-2003 05:38 PM
Buick 455???? stjoetalon Engine 6 08-23-2002 08:52 AM
