whats up guys, have any of you hot rodders ever messed around with a buick big block, a 455 to be exact, i looked up the HP numbers for the 70 model engine, which is what i have, it had 370 hp and 510 tq rating, sounds like it would be a good engine to build on, ive found a good buick performance parts dealer TA performance. is there any chance i could get this engine to run with some of the small block chevy guys around here.
The 70 motor you looked up was a "Stage" motor, very powerful and rare. Buicks make very good power and torque, they have some oiling problems, these can be cured. But, you will not be able to run with the small block Chevies without spending three times the money. Buick performance parts are hard to find and expensive. Don't get me wrong I love em and admire a strong running Flint Town Flyer. Speed Costs Money How Fast You Wanna Go!?!
basically want a mean *** street car, wont ever see interstate, might take it to the track on accasion, we have a 1/8th mile track here could i ever see some low 8 high 7 passes from it?
if i had the 455, with a poston or TA aluminum intake a 750 holley or edl carb, big tube headers, free flowing exhaust and a mild cam, would it be a strong street car? the car also has a TH400 turbo and posi rear end which im gonna change to 3.73 or 4.10 gears
Yeah, with that rear-end and a motor that your not going to be reving above 5000RPM, grandma will be passing you on the beltway. In fact your top speed is gonna be around 95MPH with a 4.10 at around 4,750RPM
If you want to run a rear like that, get yourself a built 200-4R, or go back to 3.23s
why cant i rev the 455 past 5,000? can the roataing assemly not handle it or is it the camshaft? because i am going to change to a poston camshaft rpm range 2000-6000
Can't say thats a very good idea, maybe you should go more toward a 400 or a 427, or something with a smaller stroke.
While the buick 455 does have one of the smallest stroke of the GM big blocks (3.900in) it does have a 4.313 bore, not a good idea to spend any time around 6,000 RPM, well unless you have the bottom end in perfect balance that is. This engine was built for low end to mid range power, not high RPM performance.
Get a cam for around 1,000-4,500 or the like and get yourself some 3.23s if your gonna stick with the TH400.
Some might disagree, but I'm sure most would agree that a 427, 402, or 400 chevy would be much better suited for reving around 6,000 RPM.
lol, I'm not telling you, you cant do something, I'm just saying it's not a good idea if you want the thing to live very long.
A 3.55:1 rear with a th400 would turn around 4,250RPMs at 100MPH, thats assuming you have the std 15" wheels and 65 tires.
Also if you assume that the tranny is a TH200-4R than you would only be pulling around 3,000RPM at 100MPH with the 3.55s. Trying to educate people that the 350s and 400s are a thing of the past, but no-one seems to listen
oh i know you werent telling me what to do i appreciate your advice, but i dont wanna do a tranny change and no i dont have 15 inch wheels i have a 245-45-17
You said this car would RARELY see the highway and will occasionally see the strip right??? Ok, so gear that baby down if you want to, you aren't going to be doing any extended long range cruising so don't worry about it.
Related Threads
Hot Rod Forum
2.2M posts
175.7K members
Since 2001
