Buick brakes on Ford spindles??? - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-01-2007, 11:18 PM
OK, so I've got the front brakes off of a 1960 Buick Lesabre and I want them on the front of my traditional Model T. Everyone does it by putting the drums over ford brakes, but I want to know if you can put the Buick hub on the ford spindle? I'm using the good old 37-40 ford spindles with the round mounting flange. I believe the shaft on the ford spindle is smaller than the Buick's, but can't I go get a bearing with a smaller inner race to account for this? I know, I'm probably just being a pain in the you know where, but I already have nice wheels in the Buick 5X5" bolt pattern and would like to run them. Any thoughts, advice, or other info would be GREATLY appreciated.
Old 02-02-2007, 12:21 AM
Easier to redrill the Ford hubs to the Buick 5 on 5 pattern and use your wheels than to "see" if you can make the Buick backing plates and hubs work.
But, if you want the challenge, and have the money and time to play around....knock yourself out! Maybe you'll come up with an all new swap somebody else might need!
Old 02-03-2007, 05:37 PM
Yes... you can do it but you need to make bearing adapters that slide into the hub to have the ford bearings work. A while back, a guy on the HAMB made those adapters and sold them... so i dont know if he still makes 'em or what.
And DONT THROW OUT THE BACKING PLATES!!!! You can use those. '58-'60 backing plates can be adapted with a spacer between the backing plate and spindle. And you have to modify the spindle a little, grind a flat spot on the top to clear the backing plate.
Im doing the same thing on my T sedan and so far its working out but im using a ford spindle.
John
Old 02-03-2007, 06:02 PM
Oh... found the 'good' tech article showing the whole process.
http://www.jalopyjournal.com/forum/s...ake+conversion
John
Disc Brakes for '78 Ford Courier (Mazda) Truck Bill Morgan Suspension - Brakes - Steering 1 09-25-2006 04:28 AM
Help with 9" ford rear brakes 1947chevypanel Suspension - Brakes - Steering 3 07-25-2006 10:29 AM
1973 Ford Torino Disc Brakes......... onebadmerc Suspension - Brakes - Steering 8 10-18-2005 12:39 AM
disc brakes for 1968 ford galaxie chevblazk5 Suspension - Brakes - Steering 2 08-13-2003 02:58 PM
finned buick drums with '35 ford wires 26trackt Suspension - Brakes - Steering 2 11-23-2002 04:14 PM
