buick drums - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-09-2005, 04:55 PM
buick drums
Is it possible to use a set of 45 finned buick aluminum drums on the back of my car. I think I have the front ones figured out. On the back of have a 1940's halibrand quick change with 40 ford bells and axels. do I use the 42 to 48 commercial hubs that go on the out side of the drum? Or is there another way using vintage parts, nothing newer the 1954.
Harold
Old 02-11-2005, 09:41 AM
willys36@aol.com's Avatar
Wiki Edits: 21
I can't imagine why that wouldn't work. They go on the front spindles so well and the rear brakes are similar size so should be doable. I put the Buick drums on my '56 Olds rear end and that took quite a bit of arm waiving but not too bad.
