buick regal wiring harness - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-05-2005, 09:06 AM
hey guys i am having a seriously hard time trying to figure out what all these wires are in my 1984 buick regal, i was wondering if anyone could tell me what wires i actually need and what ones i can just get rid of bc the ac and heat is all out of the car. i am putting a pontiac 400 in there also if that helps any. i am lost in that spaghetti mess. thanks
Old 08-05-2005, 09:12 AM
bracketeer's Avatar
489 Lemans
Last journal entry: Street Legal
The way I did mine was to remove the complete harness. As you unplug each item, tag it. Wipers, raidio, headlights, etc. The headlights, alt, etc unplug from the engine side of the firewall. There is a bolt in the center of the plug holding it in. The rear tailights unplug from under the dash to the left side of the fuse box. Easy to find, the wires run up near the emergency brake. The fuse box itself is held on by 2 screws.
The interior lighting is orange wires. All the black ground wires are soldered together halfway up the harness. Do not cut this section out, but peal the rubber off it so you can see it. Start cutting wires off the harness from the furthest unnecessary wire out and work your way back to the fuse box. Cut all the unnecessary ground wires off back as far as the soldered section and tape it back up. As you get going it will get easier and easier. When mine was finished it was 18 inches long. See pic for finished result.
changing engine wiring harness, ran into a lil problem ikeaguirre14 Electrical 9 06-02-2005 05:01 PM
Painless wiring harness question Big Geek Electrical 9 02-28-2005 03:30 PM
wiring harness uninstall / install boneyard Buick Electrical 2 11-03-2004 08:01 PM
ford wiring harness akm Electrical 6 03-13-2004 10:25 PM
Wiring harness from scratch, fuse values norcal02 Electrical 3 09-16-2003 11:03 AM
