buick seat belts solinoid - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-26-2006, 11:59 AM
woodmanscott@hotmail's Avatar
i am having problems with my passenger seat belt the solinoid is not unlocking the drum latch what puts power on this solinoid and when i have checked fuses and can not find any blown anywhere as of yet has anybody had this problem ? sorry i forgot .it is a 1994 buick regal3.8 v-6
Last edited by woodmanscott@hotmail; 11-26-2006 at 12:00 PM. Reason: left out make and model of car
Old 11-27-2006, 03:26 AM
docvette's Avatar
Wiki Edits: 12
Doc here,
you should have a Pink / Black wire coming from the Chime module, going to the switch..If you have signal there, It is most likely the switch..If you don't have signal, through the switch but at one side of the module, then it IS the switch.
Doc
Aftermarket Solutions
Electronic & Electrical
Innovations
Old 01-27-2007, 07:07 PM
seatbelt
thanks doc my pc crashed on me and i can not remember if i responded to you or not but i got the seat belt fixed
Old 01-28-2007, 04:08 PM
docvette's Avatar
Wiki Edits: 12
Doc here,
So what was the Fix?? A cruddy Belt switch?
Good to hear it's fixed!
Doc
Innovations
Old 01-28-2007, 05:25 PM
seat belt
Originally Posted by docvette
Doc here,
Doc
the wire was broken where it was crimped in the connector but it was on the back side did not see it until i pulled the cover off put a new plug on it and cleaned off the legs on the fuse and it went to work
this is a saver.... GM build codes TooMany2count General Rodding Tech 24 11-23-2009 10:36 AM
Where to find seat belts WakBordr7387 Interior 9 01-08-2005 11:19 PM
Bucket Seat install in 41 Buick Jackyl Interior 1 09-15-2004 09:08 AM
Where to get seat belts? BobbyG-39 Interior 3 08-18-2004 11:23 PM
Up grade El Camino seat belts stinky jinx Interior 1 12-26-2003 04:16 PM
