buick super turbine 300 trans. problem - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-10-2007, 01:02 PM
skylark65's Avatar
Last journal entry: 4 months, nothing done...
my 2 speed trans. will not shift from low to drive gear. have already checked
fluid for metal fililings and found none. filter is clean. have vacume at modulator and modulator has been replaced. car goes into low/reverse
fine. doesent even try to go into drive gear at any speed. (have had up to 70 m.p.h.) trans now out of car awaiting teardown/rebuild. Does anyone have anytips or hints on what to lookout for, anything that may be unexpected, a good
place to find a rebuild kit, or anything to try doing before a compleate rebuild?
thanks.
Old 02-10-2007, 01:25 PM
Check for a stripped governor gear.
If it is already out, may as well get the trans rebuilt. Given its age, there are probably more issues as yet unseen....
Old 02-10-2007, 01:39 PM
Will I ever get it done?
Last journal entry: Hood
Unless you have your heart set on keeping the car original, I would put in a BOP TH350 or TH400. Both better trannies than the ST300 (IMHO). Performance parts availability. Etc.
lookin 4 a buick 300 engine kit 34639 Engine 1 10-19-2007 09:37 AM
newbie question: how to lower my 48' Buick Super Conv. planet-risa Suspension - Brakes - Steering 2 03-31-2006 03:09 PM
Super Turbine 300 paul poirier Transmission - Rearend 3 12-10-2004 08:09 AM
Buick V8 to Chevy trans Smonska Transmission - Rearend 7 04-12-2003 03:58 AM
Manual Trans in 87 Buick Regal rehjr0219 Transmission - Rearend 1 02-15-2003 07:02 PM
