Buick Trannie info needed - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-12-2007, 02:35 PM
SquirrelWolfs's Avatar
Buick 1986 Trannie info needed
I have a derby car That is in need of a transmission. Buick 1986 La Sabre, 2004R trannie. Will any other transmission bolt up to 307? The cost of this trannie around here is too great to put into a car that is to be beatin' to death!!
I've checked the boards & come up with TH440T/4T60 as trannie #. At Pull-A-Part in Nashville they gave me 2004R after running my serial # off the plate of the Turbo Hydro Matic Transmission.They told me only an other would bolt up to the 307. After checking the info here, I can not find the answer. I know there must be some one here that can. Thank you for the much needed info.
Last edited by SquirrelWolfs; 08-12-2007 at 03:27 PM. Reason: Re wording & more info
Old 08-12-2007, 03:34 PM
TOWTRUCKING's Avatar
Transmision
Just Use A Regular Th 350 Out Of A Buick,oldsmobile,pontiac.it All Bolts Up The Same And Uses The Same Drive Shaft.i Run Demos Too.all You Need Is Drive And Reverse.you Do Not Need An Overdrive.
Old 08-12-2007, 03:42 PM
Thank you so very much, Your a life saver!!!
Head info needed gilby246 Engine 2 10-08-2006 09:12 AM
87 s10 2.8 v6 to 3.4 v6 crate engine swap info needed 87sdime4x4 Engine 1 07-23-2006 07:15 PM
Machining Info. Needed GoneNova/406 Engine 10 06-22-2006 08:22 PM
hi numbers match info needed for 1956 buick 2dr special glassratt Introduce Yourself 3 06-09-2006 11:12 PM
Ridler Award info needed Lee Hulick General Rodding Tech 4 11-22-2004 09:55 AM
