buiding a turbo motor please help. - Page 3 - Hot Rod Forum : Hotrodders Bulletin Board
  #31 (permalink)
Old 10-06-2011, 07:14 PM
Go to Yellowbullet.com and sign up. After which search TPI TURBO . You will find more information than you can absorb. G'luck with your build. swaZZie
  #32 (permalink)
Old 10-06-2011, 07:23 PM
TroyBoy's Avatar
Psychomotors
Good bunch of guys at www.theturboforums.com
  #33 (permalink)
Old 10-07-2011, 04:14 AM
havin fun
thanks for the tips
  #34 (permalink)
Old 10-07-2011, 07:40 AM
Banned
Originally Posted by v8mazda
wow ap, how much do i owe for all this info thanks. i'm going to print out this stuff and put it in my garage.
You don't owe anything, save it for your drivetrain, you'll need it.
Once you add a turbo into the equation it becomes pretty easy to make big power, a good turbo system is not cheap though, when you figure in the new injectors, fuel pump, exhaust, intercooler, turbo, plumbing, etc. it can cost you more than the original engine (which is why I think a lot of people avoid it). No getting cheap on your turbo system and picking the proper components is just as important as picking proper components for your engine- if not more so.
  #35 (permalink)
Old 10-07-2011, 07:57 AM
havin fun
agreed, and i already have some suspension parts and i'm adding more. i'm not going to try and rush this build i'll take my time and try to do it right. hoping for end of next summer to have it all done. motor by end of winter and then trans sent out and put all my suspension stuff on while that being rebuilt.
  #36 (permalink)
Old 10-07-2011, 08:02 AM
Banned
What hotside do you have on your turbo? You may need to keep a look out for something different depending on what you have. Your cold side is really more suited for 550hp, but if you do a good job on everything else and run a slightly large hot side you can probably squeeze out 600hp.
  #37 (permalink)
Old 10-07-2011, 08:13 AM
havin fun
i looked at that last night and i dont see any #'s. it has two ports on it if that means anything. the guy i got it from just told me 77mm what ever that means. turbo's aren't that expensive so i was thinking I'll use this one as mock up and buy the time this project is done I'll be ready to buy a better one. i had someone else tell me this turbo might be a little to small as well.
ID:	58824   Click image for larger version
  #38 (permalink)
Old 10-07-2011, 08:19 AM
havin fun
i know the paint job is out there lol but this is my other camaro. i stripped it, painted it, and built the motor. its pretty fast, i can lay 138 ft of rubber with both tires. this next one is going to be a little more mature.. something I'm not embarrassed to drive around town in lolol the green car started out as a car for my daughter... now she wants a truck so i took over the green car.
ID:	58826   Click image for larger version
ID:	58827   Click image for larger version
ID:	58828   Click image for larger version
ID:	58829   Click image for larger version
  #39 (permalink)
Old 10-07-2011, 08:41 AM
Banned
You need to measure the AR of the exhaust side, a larger AR will help give you more top end hp but will reduce your low end torque, since this turbo is on the small side on the compressor a slightly larger AR on the exhaust side will allow for better exhaust flow, requiring less boost pressure for a given hp output.
A LOT of people are not aware that the exhaust side is just as important as the nicer looking intake side. Also, what are your wastegate dimensions (if you have one already)?
This turbo uses an A/R system for scaling their housings, If you google "how to measure turbo A/R" you should be able to find a basic guideline how to do it.
Here is a link to Garrett's site with some decent turbo info-
http://www.turbobygarrett.com/turbob...o_tech102.html
  #40 (permalink)
Old 10-07-2011, 08:43 AM
havin fun
have not purchased the waste gate or blow off valve yet.
SBC Motor and a Turbo 350..Will it work? 31fordcoupe Engine 2 10-06-2009 10:40 AM
turbo 350 on a TPI motor?? punk1c5040 Transmission - Rearend 2 01-11-2006 09:19 PM
Turbo for motor ecrusch1987 Engine 6 11-03-2004 04:52 PM
400 turbo Trany with a 350 motor BowtieBubba Transmission - Rearend 5 12-12-2002 08:05 AM
Buiding a 355 need help KentuckyCamaro Hotrodders' Lounge 8 11-08-2002 10:45 AM
