Build a 327 on a 350 block? - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-04-2006, 11:25 AM
i just traded into a 69 327 engine that had been re worked. when i took the heads off (305's) i found it had been bored 0.40 and is worn.
i don't have a micrometer but there are waves near the top. i believe it is a large journal
what i want to know is can i swap the crank,rods and pistons (dome 10.3 to1)
into a good 350 block with out changing deck height ? or would it be better to rebore the block i have ? i have a fresh set of 69 2.02 64cc heads &
Q jet. any info, suggestons ? also what cam recomendations? it's going in a 74 nova with a Th350. w/3.73 10 bolt. i won't be racing it, but i want a clean running combo for highway speeds with decent mileage. i kinda wanna keep the block i have, (a nostolga thing) but don't know about boring more?
Old 06-04-2006, 11:30 AM
woodz428's Avatar
Troll Hunter
If it is a large journal crank, it should be a drop in. Now, the cost feasibilty would depend on what you could get a clean std. bore 350 block for.
Old 06-04-2006, 11:46 AM
xntrik's Avatar
Save a horse, Ride a Cowboy.
I would not recommend reusing worn .040 pistons, of course, the cylinders could be sized specifically for the piston clearance. The additional machine shop expense might almost offset the price of new decent pistons.
Old 06-04-2006, 11:06 PM
Thank you for the info.
had i looked a little more i see lots of post's about this.
i should have ask here before i swaped a running 350 and a AOD for what turns out to be a 327 crank,and 305 heads.
i'll be looking for a good 350 block and start there.
if i have to bore and buy new pistons i may as well build a 4 bolt.
also, will i need the short block assembly balanced?
Old 06-05-2006, 09:46 AM
MI2600's Avatar
Member# 3287
If you are going to use the same rotating assembly, i.e. crank, rods and pistons you'll be ok. If you change anything I'd rebalance.
Old 06-05-2006, 09:59 AM
solidaxel's Avatar
Last journal entry: Project garage complete!
Cut your losses, sell all the parts and buy a new Mr. Goodwrench and drive it like you stole it.
Chevrolet 327 TEEMCDEE9552 Engine 15 06-09-2007 08:22 PM
Building 327 with 350 block? projectjohn Engine 10 10-02-2005 06:36 PM
350 block 69 chevelle SS Engine 7 09-02-2005 02:21 AM
327 or 350 chevy (please no rookies) chris oswalt Engine 16 12-11-2004 08:29 PM
350 Chevy build Streetmachine Engine 11 12-10-2001 04:31 PM
