build a 383 stroker
what kind of cam should i get for my stroker motor if i am runing a edelbrock preformer manifold, 750 carb, claimer pistons, power pack heads, what kind of cam specs do i need to be looking for if i want raw power from idle to 5,500 rpms?
Here is a site with over 100 combo's on building a 383.
http://www.ryanscarpage.50megs.com/combos1.html
Luv the smell of NITRO in the morning. |
383 Stroker
Having just built one of these I have some thoughts. AFR recommends 195cc intake runners with 2.02 & 1.60. These heads flow 263 cfm at 550 valve lift with this being the max. Comp cams recommended for their solid lift flat the 294S. It's pull is from 2500 to 6300. We then added 1.6 rockers which put us at 550 lift on the valves just what the heads needed. The Air Gap intake and the Mighty Demon 750 dyno'ed 537 HP. I have it in a 69 Camaro with a 4 speed and 4.10 gears with 27" tall ET's. The fastest time yet for the car is 11.43 @ 116 going through the traps at 5,200 on the tach. I believe the car will go 11.20 with a set of 4.56 gears so I could get in 4th gear quicker. As it is now it can be driven every day with no problem.
I will also tell you a small block makes Horse power with good heads. With small intake runners you will have so much torque up to say 4,ooo RPM and then nothing after that. The 383 is a great motor but it has to have good heads to really come alive. Spend the money on the heads. |
I bet adfishe's Camero really rips, but his specs are a little more than the rpm range you are inquiring about. AFR's new designed 180cc runner head only flows 5 cfm less at .550 lift than the 195 spec quoted. Although look more at the mid lift flows for a better average. Your valve is only max open for a short time. The smaller runner heads will give you good velocity at lower rpm's for better power. Look for 6 to 8 weeks to get a pair though. The 180cc Pro Topline is another top contender, that is readily available and a little less money. For your cam, i would look towards the 220 degree duration mark, plus or minus (at .050 lift rating). 260 to 280 advertised duration. For lift i would shoot for between .45 and .55. Use some 1.6 rockers to get there. A roller cam will also get you better power, vs the same spec cam in flat lifter style. Do not chince on poor heads, they are the most important piece to choose.
