Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Build or Buy an X-member?
Old 10-18-2008, 10:06 AM
Deuce Deuce is offline
It is also a GOOD idea ... IMHO
to make the crossmember where the transmission support bolts in/out so you can remove the transmission without having to pull the engine .
You can see here how further bracing was added to the crossmember after the first photo
