Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Build or Buy an X-member?
Old 10-27-2008, 01:44 PM
SinistrV6's Avatar
SinistrV6 SinistrV6 is offline
valve monkey
Originally Posted by Deuce
It is also a GOOD idea ... IMHO
to make the crossmember where the transmission support bolts in/out so you can remove the transmission without having to pull the engine .
You can see here how further bracing was added to the crossmember after the first photo
Do you remember what the specs were on that tubing? Or what you'd recommend? Don't want to fab it up from the wrong material!
