Build the garage or finish the car?
OK I have a problem though it's a good problem I guess. I'm working on a 68 Camaro that is currently driveable and not bad looking (from 10 feet :P ) but it does need paint. My current work space is a one car garage with everything I need except the space to actually work on the car. I have already started on a new motor and have alot of new parts that will be installed.
My question is do I build a new 28' x 44' garage and finish the motor and such in a year or two or do I finish the car this winter and struggle with the lack of space? Thanks for the advice Zammer |
No brainer there. Build the garage :thumbup: You can let the car go until it is a 20 footer. LOL!!!
Definitely build the garage...once that is done the work on the car will go so much easier and faster..
Sam |
Yep , finish the garage first.... wouldn't want to make that ride all shiny and have no where to put it :nono: :nono:
BTW - not a bad predicament to be in :mwink: |
Garage all the way. I have seen too many times something stops you in the middle of a project then it stays outside and by the time you get back to it you have to re do everything you did. :thumbup:
Build garage or finish car
#1, build garage. #2, build garage. #3, build garage. It will make EVERYTHING go so much easier. Oh yeah, BUILD THE GARAGE!!
Build the garage first!!!!! :nono: :thumbup: :thumbup:
Finish the car!
Sorry, just being the voice of reason :P |
Shane |
No, No, No...everyone has it wrong. :nono:
Build me a garage. :thumbup: Then you can go finish your garage and then your car. :D |
build it and heat it.
Build the thing and heat at least a section of it. Then when it's cold you don't have to be sitting inside watching crap on TV. You can be in your nice garage wrenching.
Garage first - drive the car and have fun while the garage is built - finish the car when you have space, at least then you can work at your leisure while saving more money to finish the car.
I'll make it 9-1 in favor of the garage. Although I really like Brian Bs idea. I'm in need of a really nice garage myself.
28x44?...You can put 4 cars in there....plus your junk.
Garage. |
Zammer,
Whatever you decide on the garage, be sure to get something like these: http://www.hamiltonhomeproducts.com/...garheaters.htm http://www.mrheater.com/productdetai...atid=50&id=117 http://www4.modine.com/v2portal/page...ontent_014.htm :thumbup: |
| All times are GMT -6. The time now is 11:54 PM. |
