Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Build my 327
Thread: Build my 327
Old 08-02-2007, 01:24 PM
454C10 454C10 is offline
You are right. That isn't a cam for bottom in torque. However, he didn't ask for bottom end torque. He whats 400hp and neck snapping torque. That is what the gears and high rpm stall converter is for. The engine will not spend much time in the lower rpms and will have neck snapping torque in the upper rpms. Plus, it takes a good amount of duration to make 400hp with a 327. A short duration low rpm torque cam will fall very short of the 400hp goal.
