to build or not to build - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-10-2004, 02:40 PM
New Member
I have a 85 monte carlo I just bought with a 305 tbi truck motor in it. I'm wanting a bigger motor and was wondering should I go to a junk yard and get a 350 and take it to a machine shop or just wait for a while till I get enough money for a crate motor. The one I like is the GM goodwrench 350/330 but is $3600.00 If the junk yard is the way to go what should I look for? What price to pay.?Do I have to find a tbi motor or go with a carburated one? Or am I going in the wrong direction an try to do something with the 305? I new to this as this is my first sbc that I have owned and I'm not trying to race just wanting more performance than what I am getting. Heard good and bad things about 305's. Thanks for any help!
Old 05-10-2004, 05:04 PM
1BAD80's Avatar
The Smell of Nitro in the morn
Last wiki edit: How to adjust valves Last photo:
Wiki Edits: 2
Get the GM crate motor with warrenty.
Luv the smell of NITRO in the morning.
Old 05-10-2004, 09:07 PM
If you have NOT ever built a engine..........most definitely buy a crate engine. The ZZ4 is just a little more the the one you are interested in. Some Chevrolet dealers have their own ZZ430's for less than 5 grand. 430 horsepower will really push the Monte Carlo.....
If you have built engines in the past...........you may save a few dollars and get a stronger engine by doing a lot of the work yourself. Carefully selected 'used' pieces combined with NEW stuff can make for a very powerful yet drivable street engine.
Bigger is BETTER........and size does count.
You can build a stroked 350 (383) for small money.......not much more than a standard rebuild. SBC 400's are great for moving heavy cars too ......a .030 overbore makes for a 406. Easy to get 375 - 400 horses .
DEUCE..General Rodding Tech Moderator
Old 05-11-2004, 05:25 PM
1BAD80's Avatar
Wiki Edits: 2
build your own 430 hp motor.
http://www.sallee-chevrolet.com/Photos/zz430pics.html
Old 05-11-2004, 07:21 PM
HemmiGremmie's Avatar
Last journal entry: 52 truck
Crate motors are a great way to go, but only if you can actually save the mo0ney for it or have the money for it.
I always get started saving, but spend the money on other things that pop up. Its way better off if I build a little at a time. HG
I was built with the body of a God! To bad it was buddah.
Hemmies rat journal below.
Old 05-11-2004, 10:56 PM
Sudden Psycho 31's Avatar
it is very satisfying to do your own buildup...
if you are new to it, which i assume you are if you are asking... just switching motors is extensive.
if you still want to tackle it, make sure you have someone at least slightly experienced to double check your work. you will save money
very satisfying when done right, expensive and frusterating when done wrong.
good luck,
31
Old 05-12-2004, 12:22 AM
bonuts's Avatar
Got Ouzo for touzo
I'd build my own. For a fraction of the cost of a crate motor, get the machine work done, buy your own parts.
I just had my engine for my race car done. Machine work, cam bearings, and pistons pressed on rods was around $350 CDN. The pistons were $180 for .030 flat tops with the 2 valve reliefs. Plus bearings are cheap, so really if your on a tight budget building your own would be a good way to go. Assuning you have the urge to learn to build a engine.
I guess if money isn't so tight a crate engine would be the way to go, with a warranty etc. I'm going to have my engine ready to go for under $800. I did already have a 350, and a steel crank so that would have added some money.
bonuts
Old 05-12-2004, 03:47 PM
New Member
I would love to tackle it myself but just didn't know what direction to go in. Any help on where I should start or steps I should go in would really help! Not a cheap skate, just want to build a good engine and do it right. Wasted money thinking the higher the price the better it is and thats not always right. As always thanks for help you all are giving me. The car is not a daily driver. Just want something with good horsepower and tourqe and fun to drive.
Old 05-12-2004, 09:27 PM
Sallee does sell their version.....but......I do not need it ...
I have one of the original GM versions.....
Number 430.......the very last one......
