Build your own frame! - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-23-2006, 05:42 PM
Nightfire's Avatar
Young & Idealistic
Last journal entry: 1950 Fargo - losing hope
Wiki Edits: 4
Hey guys, saw this over at the H.A.M.B.
It pretty much shows your how to build your own model A type frame right at home.
http://www.jalopyjournal.com/forum/s...ad.php?t=87556
Mike
Old 01-24-2006, 03:50 PM
Rob Keller's Avatar
AKA:"SLOWRIDE66"take it easy!
Wiki Edits: 38
labor intensive !!
But at least you will know its new!!
"SlowRide66"
"Illegitimis non carborundum"
Old 01-25-2006, 02:31 PM
farna's Avatar
Last wiki edit: AMC V-8s Last photo:
Wiki Edits: 14
It doesn't have to be that complicated though, not if you're going to channel the body over the frame anyway. Then it's just a couple straight rails that angle in toward the front that are Z'd in the appropriate areas with whatever suspension hangers needed welded on. Using a T type front axle set up, transverse leaf or coil overs, there's only the Z in the back. When I Z square tubing, even a small amount, I don't cut and gusset like that guy did on the front. I cut a "pie slice" out the appropriate size, leaving one side intact, then bend that up (or down, or even sideways) and weld the three sides. Of course another "pie slice" on the opposite side needs to be taken out.
Straight rails up to the axle with the tapered "sculpted" rails in front would be a nice compromise if the body is over the rails. But is you want something with the look of an original frame, sculpting rectangular tubing is much easier than starting with flat plate!
59 Chevy pickup frame woes! Li'l Pine Suspension - Brakes - Steering 33 07-08-2009 08:24 PM
Roll Bar Install Advice Mustangsaly General Rodding Tech 12 12-02-2007 08:33 AM
Critique My Frame STATUTORY GRAPE Suspension - Brakes - Steering 23 12-21-2005 08:51 PM
Front clips and frame swaps --- More work, less value Centerline Suspension - Brakes - Steering 23 05-25-2005 08:42 PM
repairing a cut up frame jniolon Suspension - Brakes - Steering 3 04-12-2002 06:42 AM
