Build Your Own Front Axle
I see a lot of homebuilt vehicles but something I haven't found was information on how to make your own front drop or straight axle.
I know its probably cheaper and safer to buy one that's already made. But for those who would like to build their own or how they are built for educational purposes would be ncie just to know in case one decides to give it a try. Delta |
Dirt Track
Racing we used to make our own axles touchy part was milling the king ping bosses and getting the cambers and caster correct. we used 1/4 inch walled square or rect tubing
Homebuilt Front Axles
So the front axle of a Model A or any hotrod for that matter are 3 separate pieces?. One straight piece and the King Pins are welded to the ends?
Delta Racing we used to make our own axles touchy part was milling the king ping bosses and getting the cambers and caster correct. we used 1/4 inch walled square or rect tubing |
CCR T Bucket plans
CCR sells plans parts and raw materials to build T buckets. the plans have a couple pages on how to build a tube axle, They aslo sell the individual parts, tube and end boss, I built a couple of chassis but had 2 tube axles. I.ve had the plans and catalog for about 20 years, the price in the old catalog was about $ 100 for axle parts , A couple of local steel suppliers ordered the Dom tubing and had the frame rail material in stock for about half of the ccr prices. I found a hay wagon with a 46 Lincoln I beam axle and the good brakes for $ 25 and a trailer with a Ford I beam and Model A pickup box cheap so have shelved the Idea of building my own axles
Caster
we used as much as 9 degrees caster and 3 degrees camber. we had to ream the king pin bosses by hand. this was Dirt track racing
| front axle | demon1 | Suspension - Brakes - Steering | 3 | 09-01-2007 01:23 AM |
| front axle ??? | Gr8lite | Suspension - Brakes - Steering | 2 | 11-28-2005 11:50 PM |
| 4x4 axle conversion ttb to solid front axle. | Jared | Transmission - Rearend | 6 | 11-07-2005 08:50 PM |
| 31 rod front axle | WilderRods | Hotrodding Basics | 2 | 01-31-2005 04:06 PM |
| front axle | ruttro | Suspension - Brakes - Steering | 2 | 07-14-2003 09:11 PM |
