Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Building a 283 into a 302 or 327
Old 10-20-2006, 10:30 AM
CNC BLOCKS NE CNC BLOCKS NE is offline
Originally Posted by trbomike
Thank you all for the input. I guess I should have stated this is a 65 Nova and I want to use an original block for appearances. In case you weren't aware, the oil filter is cut higher into the block, and there is a threaded hole in the side of the block where the clutch ball for the z rod goes. So a 350 is out. It really doesn't matter to me what size I end up with. I can bore it .060 and use what I have with new pistons. I'm not going to thrash it; I'm really just after the original look. So, bore it .060 over and stay with all the stock internal lower end?
Just make sure you have the cylinder sonic tested befor you do anything so later on you won't end up with a pile of junk.
