building a 327 - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-23-2010, 07:01 PM
alleeclan's Avatar
building a 327
i am thinking of rebuilding a 327 i have , its a .030 over steel crank small journal motor with 2.02 / 1.6 heads that have have 62 cc chambers . i have heard this is the combo that made 375 hp . anyone know if this is right ? if so which cam , carb were used ? where can i find the exact specs to recreate this ? anyone have any thoughts on how more power can be made with these parts used as a starting point ? (no bottle)
Thanks
p.s it has flat top pistons with 2 valve reliefs
Old 05-23-2010, 07:45 PM
302 Z28's Avatar
The fuelie motor was rated at 375 horsepower in 1964. Later years 327 were rated at 300 and 350hp. They had forged pistons usually around 10 or 11 to 1 compression. I believe only the fuelie motor had the mechanical camshaft.
Vince
Old 05-23-2010, 08:39 PM
TucsonJay's Avatar
The fuelie would have been a 375 horse engine. The 365 was the same engine with a small Holley and high rise intake... the same 202 heads... and the same solid lifter cam. These were 11:1 compression or better, and had "pop up", or domed pistons. The flat tops might mean a 300 horse shortblock, or a piston change. You will have trouble finding fuel, if running the domed pistons, unless you lower the compression somehow.
Old 05-23-2010, 08:42 PM
A friend of mine bought a 65 chevelle(malibu) new, ordered with a 327/365, Muncie. If I'm not mistaken, that motor had a 30/30 solid cam. The 375hp might use the same cam, I think the only difference was the carb/intake...correct me if I'm wrong. I think Crane still makes "copies" of these cams...but there's better ones out there now. I did buy one of those copies...but I gave it away before I tried it out (the specs didn't look impressive).
Old 05-24-2010, 07:42 PM
alleeclan's Avatar
anyone want to guess what the compression is with the flat tops and a 62 cc head . probably use an off the shelf felpro head gasket , just a general idea . im guessing somewhere between 9:1 and 9.5:1
advice/thoughts/suggestions 327 build 1968ccaammaarroo Engine 18 04-23-2009 06:23 PM
building a 1966 327 wanting advice djackson88 Hotrodding Basics 13 03-04-2009 08:45 PM
max hp out of a 327 harley83 Engine 20 02-09-2009 11:02 AM
help make my 327 angry!!! 70chevelle327 Engine 40 04-24-2007 05:33 PM
Need help Identifying 327 & Double Hump Heads & Holly 63ChevyII Engine 9 09-07-2004 05:46 PM
