Building a 327 I really am.. Slowly - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-14-2008, 10:22 PM
chevy350_Camd's Avatar
VROOOM !!!!!!
Last journal entry: This is the Rough Draft of the V8 Frame
Ok I have found a crank and was wondering if this crank would work for a 327 3.250 95120 CA49206 350 350 56 1/4" KEY @ 0 DEG. 2 G10
Could I put this into a 350 and still have a 327 or what would I have to do ?. Is it the Bigger bearing crank that was worse than the other ?. Would this work for a 327 Chevy in a 350 Block, would it pretty much be the exact same ?. Thanks
Old 05-14-2008, 10:37 PM
Wiki Edits: 31
3.250X 4.00 = 327 CI you need a large journal 327 crank tho, not sure if thats what you got
Old 05-15-2008, 07:46 AM
Double_v23's Avatar
Horsepower Enthusiast
Last journal entry: Finished BMOD001FH
You would need 327 pistons with the 3.25 stroke and 5.7 rods. You would need a piston that makes up the .230 difference in stroke so if a 350 piston has a compression height of 1.550 than you would need a piston with a compression height of 1.780.
And no, the bigger bearing crank is the better of the two and as stated above it is the one you need to make this work.
327 '89 Trans Am GTA suggestions 3rdGenFreak Engine 2 06-29-2007 08:45 PM
Chevrolet 327 TEEMCDEE9552 Engine 15 06-09-2007 09:22 PM
Difference between a 327 and a 350? 327ImpalaSS Engine 16 11-19-2004 06:33 PM
Need help Identifying 327 & Double Hump Heads & Holly 63ChevyII Engine 9 09-07-2004 06:46 PM
350 or sj 327 chevyman17 Engine 4 01-22-2003 12:07 PM
