Plus he does not have a big rear (or maybe he is just skinny)... Run the calcs based upon his description and see what times come up. |
http://www.google.com/search?q=1/4+m...&start=10&sa=N
Most of these use horsepower at the tires........ not the flywheel. |
327
So what you all r telling me is that I can't do much with a small journ. 327 so I need to stick with the 350. If so is the 383 my best option?
327
Ok OK listen with what I have told you and I know I will need ignition and stall and a 2 speed powerglide doesn't sound bad maybe with a trans brake or somthing .I will also be running a 250 shot. The carb I have right now is a worked up 650 holley pumper. I have a intake choice of Edelbrock air gap, performer, victor jr clone, street dominator. Don't know what heads yet ,I'm still studying. I like the 3917291 heads with the 2.02-1.60s like they used on the 302. I just want to do this right the first time and have a nice head turner strip and street. Think I could lift the tires with this thing? I would really like to shut alot of people up around here honestly. Like I said thay think if you do not have a 383 you can't run, I want to say I can run just as fast as your full drag car and still drive it home ( Iwouldn't really drive it everyday but I would sound cool saying it!)HE HE. I do not have a thought on a gear yet right now it is stock.I want 4 link but...... Hey do you know how to post pics on here?Please step me thru it!
You have to remember that you have a very short distance to get your times in with the 1/8th. This takes brutal torque to get you moving which the 327 is not optimum for. Yes, you can get the front wheels off the ground with a 327, but it will take dollars and you will have to compromise on streetability. If you were running the full 1/4, then that's a different story as you have more distance to take advantage of the rpm's... |
The old saying.... There ain't no replacement for displacement. Somebody else said, "Speed costs money, how fast do you want to go?" Bigger makes more power, consumes more money to build, consumes more money to feed. (eats gas, eats transmissions, eats rears, eats tires, etc.) Small journal 327s are fine engines. But your expectancy should realize that it is a 327 and gives up 52 cubes/ 52 hp just by its size compared to a 383. (383-331= 52) It can produce adequate fun power for the street, if you accept that it is not going to be the quickest car, or even close. It can be fun to play. That is all we are saying. If you are like 96% of us that come to this site.... you always wish you had built more power. WE ARE POWER JUNKIES. People that "know" say it is worse than cocaine... But sometimes you just have to have a limit, and live with it. What was the original question????????
327
I swear on my dead mothers grave on this motor ... ill post my time slips on here tomorrow... ever heard of hi rev racing engines out of granger Indiana??? The top engine builder there is Jim gaugler? he built the 327 that I ran in the camaro... heck this guy had a 69 camaro that coasted doing 9's in a quarter at osceola dragstrip in elkhart Indiana... HI REV... SO HOLD YOUR HORSES HERES WHERE THE SOURCE IS
Sure it can be done. |
OK so I trash the 327 idea for this project and go with the 350, What should I do to this motor to give it 500 horses or as close as I can get? Give me the goods or tell me what motor I should build for this app and I will start looking! I am glad I found this site! This could be the start of a beautiful friendship!
Your "street car just barely, 1/8 mile drag" (post #1) lets us spend a lot of your money.....
Are we starting with a bare 350 flat tappet block, or a 5.7 roller engine fully assembled donor?? If it is a bare block of either, you can make it a 383 for not much more money. Do we have $ 5000 to work with ? |
Short Block:
4340 Forged 3.75 or 3.80 stroke crank, 4340 Forged H-Beam rods, 11.5:1 - 12:1 Forged Pistons Top End: AFR 195cc Runner Heads, Solid Roller cam 240-250* duration at .050 lift 106-108* centerline, 1.7 roller rockers, Edelbrock RPM Air Gap intake 750 Holley HP DP Carb That should get you started.....others may chime in with better choices |
327
| Building A 302 Chevy | Scorpio Shaping Flow | Hotrodding Basics | 6 | 01-16-2007 05:55 AM |
| Decoding Ford Small block | hotrodgs | Engine | 16 | 05-14-2006 05:15 AM |
| rebuilt chevy 327 small block wont fire | 78 Nova | Engine | 3 | 01-12-2006 05:54 AM |
| need info on small block chevys | engine-rookie | Engine | 1 | 05-03-2003 08:48 PM |
| big block or small block ford? | stangfiend | Engine | 3 | 12-10-2002 09:55 AM |
