BUilding a 327 small block - Page 4 - Hot Rod Forum : Hotrodders Bulletin Board
  #46 (permalink)
Old 01-16-2007, 10:13 PM
Burnt rubber and Raceing gas
Originally Posted by kuhn-77
Short Block:
4340 Forged 3.75 or 3.80 stroke crank, 4340 Forged H-Beam rods, 11.5:1 - 12:1 Forged Pistons
Top End:
AFR 195cc Runner Heads, Solid Roller cam 240-250* duration at .050 lift 106-108* centerline, 1.7 roller rockers, Edelbrock RPM Air Gap intake 750 Holley HP DP Carb
That should get you started.....others may chime in with better choices
So what king of power are we talking about?
  #47 (permalink)
Old 01-16-2007, 10:19 PM
I think I posted my reply th wrong way. So....What kind of power are we talking about here? Others are welcome with thier thoughts. I want to use this knowledge to build a weapon
  #48 (permalink)
Old 01-16-2007, 10:25 PM
kuhn-77's Avatar
Build it right the first time
On the safe side minimum I would guess about 475+, a freind of mine had a very simular combo N/A 388(.030 over 383), 12:1 comp, AFR 195cc, I dont know his cam or intake though, but his put out peak 503hp on the enigne dyno
  #49 (permalink)
Old 01-16-2007, 10:28 PM
Lonestar's Avatar
"May the Schwartz be with you"
Last journal entry: Finally getting going...
I have never checked on this, but it seems that I have been told a big block Chevy will fit in those S10's with minimal mods...if so that would be the way to go.
In fact a '70 455 Buick warmed up a tad would get you a nice little 1/8th rocket...if you can get it to hook.
Like I said before, 1/8th of a mile is not a long distance, so the trick is to get as much off the line acceleration as possible. A big block would do that at a low rpm therefore decreasing wear AND making a nice dayly cruiser to boot.
  #50 (permalink)
Old 01-16-2007, 10:55 PM
Yea I have thought of that but it would put me in a diffrent "CLASS" if you know what I mean. I think I want to stay SB but I am sure once I put this in mt pocket i'll be looking for a big block.
  #51 (permalink)
Old 01-17-2007, 12:05 PM
King of my Man-cave.
Personally, I would build the 327. Go with 11:1 compression, 302 Z-28 solid cam, port the 291 heads, etc. You will have around 385-390 HP, it will wind like crazy. It may not be as powerful as a 383, but it will turn heads and won't be the same old mill everybody else is building.
tom
  #52 (permalink)
Old 01-17-2007, 12:13 PM
Lonestar's Avatar
tom
Tom, I would completey agree with you if it wasn't for the fact that he wants a 1/8th mile rocket.
  #53 (permalink)
Old 01-17-2007, 12:39 PM
runn141's Avatar
for the 1/8 mile i would build an s10 pickup on a 2 wheel drive blazer frame for the shorter wheel base
  #54 (permalink)
Old 01-17-2007, 03:47 PM
well it is a s-10 blazer. I was told the blazer would hook better than the pickup.But I took apart the 327 today and it already has 30 overs and the ridge thats in it will take another 30 to 40 thous to clean up. so that would leave me pretty thin. So I am forced to use the 350.Now what should I get first ?heads?
  #55 (permalink)
Old 01-18-2007, 01:03 PM
runn141's Avatar
the s10 pickup will hookup just as well it is the long wheelbase and ext cab truck that wont, because ive experienced everyone.
  #56 (permalink)
Old 01-18-2007, 01:36 PM
Sell the 350, 327, 305, 283's and put the money into a good build based on a 400. Tell everyone it's a 327 and spin it to 6K with NOS. It'll also be more streetable and quicker with less gear.
  #57 (permalink)
Old 01-18-2007, 06:14 PM
runn141's Avatar
ive outrun other s10's with 406's with mine and all i had was a 350 .040 over.
  #58 (permalink)
Old 01-19-2007, 06:54 PM
building a 350 somthing
What is the best place to research engine parts like What is the best head to use for the 1/8 and what is the best cam to go with the heads,intake etc......
Building A 302 Chevy Scorpio Shaping Flow Hotrodding Basics 6 01-16-2007 06:55 AM
Decoding Ford Small block hotrodgs Engine 16 05-14-2006 06:15 AM
rebuilt chevy 327 small block wont fire 78 Nova Engine 3 01-12-2006 06:54 AM
need info on small block chevys engine-rookie Engine 1 05-03-2003 09:48 PM
big block or small block ford? stangfiend Engine 3 12-10-2002 10:55 AM
