Building a 350 Chev with a Cragar blower, does any one have any info or opinions ?? - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-18-2008, 10:10 AM
http://www.youtube.com/watch?v=xBs0upEfTrU
Hi guys,
I am an aussie in Perth. i have added a quick video of the car its second trip out to the track... after much deliberating I have decided to build it as a blown show / burnout car... For those not in the know it is a Holden LH Torana with a 350 chev / toploader / 9 inch and all the fruit.. at the moment the motor is basically stock with edelbrock chrome gear all over it and a RPM air gap manifold and a 750 carb...
I have purchased a Cragar Blower and would like some info from people who know these blowers what setup I should be running as upon taking my motor out to strengthen her a little we have realised the heads need replacing and the bottom end is all new but stock...
I am looking to stay in a mild HP range of 500 - 600 hp and not go all out on the $$$... so far I believe a edelbrock victor Jnr set of heads with roller rockers will do the trick out of the box and I need forged pistons / rings.. and I am not too sure on what spec and brands to go for the rest of the internals...
Much appreciated if anyone could asist.
Cheers
Dave
ID:	31919   Click image for larger version
ID:	31920   Click image for larger version
ID:	31921   Click image for larger version
Old 08-24-2008, 03:04 AM
Does anyone have any info to give on what pistons / cam / chonrods / rings / bearings i should use?
obviously were going for a low compression.. what cam best suits a 6/71 blower? will the original heads be sufficient with new springs / rockers ect...?
Any info would be great.
Cheers
Distributor Tuning and Theory - Part 1 Rick WI Engine 35 04-26-2011 01:38 AM
Big chev 454 and small chev 350 bolt pattern boneyard Buick Engine 4 01-18-2006 10:07 PM
4-71 Blower Many many questions and opinions needed HELP!! please!!! Warrant Engine 18 12-21-2005 01:33 PM
I'm building a sbc 350 need input PLEASE the ernster Engine 8 07-13-2005 02:56 PM
Building a 350...any suggestions? Custom95Z Engine 4 04-02-2003 08:47 PM
