building a 355 - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 03-18-2009, 12:02 AM
did some research and found this
so beehive springs (26918) have a inside diameter of 0.885 and will need no machining on the vortec heads
now regular springs (981) have a inside diameter of 0.880
so according to these measurements wouldnt that mean that regular springs will fit as well without any machining done????
  #17 (permalink)
Old 03-18-2009, 01:34 AM
F-BIRD'88's Avatar
Yada Yada Yada
The damper is not included on the ID spec on the 981 springs.
  #18 (permalink)
Old 03-18-2009, 10:45 AM
actually they are included
Building blown 355 motor ssmonte Engine 5 11-29-2005 06:15 PM
Thinking about building a purpose built nitrous motor! Please critique leemoses Engine 22 06-19-2005 10:15 PM
Building Lift kit. D200Dodge Suspension - Brakes - Steering 10 01-18-2005 04:08 AM
Finally started building 355 Gettheledout Engine 1 11-14-2004 07:27 PM
which one to turbocharge 355 or 400 TerroRx7 Engine 11 10-13-2004 06:45 PM
Copyright ©2000 - 2014, vBulletin Solutions, Inc.
