building a 355 - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-23-2009, 11:00 PM
building a 355
this is my first build and i have done my research thoroughly but i would like to get some feedback on the parts that i will be using for my build...
so to start off im looking at around 350hp - 400tq and a compression no more than 10.5:1
the block is 3970010 (010 front of block) bored 30 over
vortec heads 062 - 64cc 1.94/1.5
comp cams 26915 springs beehive
comp cams 787 retainers
comp 648 locks
comp 7812 rods
comp 1417 1.52 roller tip arms self-aligning
comp cl12-211-2 cam/hydro lifter kit - .050 lift 224/224
maybe speed pro zh345ncp30 aluminum pistons 4.03in 5cc
clevite sh13495 cam bearing
clevite ms909p10 main bearing
clevite cb-663p10 rod bearing
intake performer rpm w/ 750cfm edelbrock
as for the crank and rods ill be using my stock ones... and for the pistons im still not sure... considering 2 of them have broken skirts... im thinking of changing all of them or maybe just those 2
IMO this seems like a good street build but considering its my first i would want to get some feedbacks from builders...
thx for any help
Old 02-24-2009, 12:12 AM
i also wanted to add that i dont want a rough idle... it will be a daily driver... i also want a good vacuum reading
Old 02-24-2009, 09:10 AM
That's somewhat similar to my build, although I'm not incredibly familiar with all the details of the parts you selected...
I'm using an Edelbrock 7102 cam (.050 lift 234 int./244 exh.), KB 9902HC 5cc flat top pistons, vortec 062 heads, and a Holley 670 Street Avenger carb...
I used the stock rods and crank, too...
My idle is moderately rough, but I like it. My vacuum reading is kinda low, but I've already tagged it to be addressed in the future. My carb is performing, so I can put it on the back burner...
Old 02-24-2009, 09:24 AM
im guessing your using stock spring on the vortec heads cuz you dont get much lift with that cam... but how about power... do you know your numbers my main concern is rough idle... cuz when i check my cam seems like big numbers for a daily driver
Old 02-24-2009, 09:49 AM
F-BIRD'88's Avatar
Yada Yada Yada
Two recomendations.
The cam is more cam than you need to achieve 350hp. it does not have a smooth idle.
Better cam is Summit #1103(K) or comp cams (CL)12-238-2 Xe262.
Both these will exceed 350hp in your motor and have better low end and overall torque and idle quality. Use a 1.6 ratio self aligning type rocker arm comp #1418-16
This cam/1.6 rocker combo will give you more valve lift that the 270H cam/1.5 rockers with torkier duration specs. very near or matching hyd roller cam performance at low cost.
The summit cam makes 374hp in a 10:1 350 with vortecs and a RPM manifold/750carb.
I ran this exact combo for many years. It's a good one. The comp XE262H-10 is a good one too. It will equal or exceed the summit cam.
Both, have better drivability and are much better with a stock torque converter.
If you don't want a Summit brand cam (they are made by Crane)
use a Crane Blue Racer #WG1159. or comp 12-208-2 (its the same thing)
Use a KB flat top piston (the budget friendly claimer series are just fine)
The FM h345NP piston has a reduced pin height. If you cracked two, the rest are stressed now.
One more. Instead of buying the GM 062 vortecs and then the comp valvetrain to upgrade it why not just buy the New GM small port Bowtie vortec head. GM/summit #25534421
http://store.summitracing.com/partde...5&autoview=sku
Its ready to rock for .530" lift and is a better quality head with improved hi velocity ports and thicker cast decks and light weight quality LT-4 2.00" x1.55" valves.
If you have your machinst "Odeck" the block for the new pistons and build to spec, the cr will be 10:1 right on the nose. 10.5 is more than you need.
If you build to these specs I know it will exceed your expectations and drive nicer too.
Old 02-24-2009, 10:16 AM
Originally Posted by F-BIRD'88
Two recomendations.
The summit cam makes 374hp in a 10:1 350 with vortecs and a rpm manifold.
I ran this exact combo for many years. Its a good one. the comp XE262H-10 is a good one too. It will equal or exceed the summit cam.
Both, are much better with a stock torque converter.
Its ready to rock for .530" lift and is a better head.
If you build to these specs I think it will exceed your expectations and drive nicer too.
well im getting the vortec heads pretty cheap 200$/ea with springs and valves
Old 02-24-2009, 10:23 AM
F-BIRD'88's Avatar
Yada Yada Yada
not with beehive springs you won't. Are these used vortecs off a truck?
Here is a complete summit rebuild kit with +.030 pistons and 10-10 bearings
http://store.summitracing.com/partde...1&autoview=sku
Spend the money I saved you on new bowtie vortecs and the cam/ rocker combo. You won't regret.
Old 02-24-2009, 10:34 AM
w/o beehive springs but its new heads
Old 02-24-2009, 04:47 PM
I don't know my numbers other than my compression ratio (10:9:1). I'm suffering transmission issues, so I'm waiting to get those resolved before I have placed on the dyno...
Yeah, I used stock springs...
Old 02-24-2009, 06:47 PM
beehive springs from my point of view are simply a waste of money in your case. I would look into having the spring seats cut for a bigger diameter and then installing a $40 set of springs for your 'mild' build. just my opinion though.
Old 02-24-2009, 06:57 PM
ill see how much it will cost me at the sop because getting beehives will get me around $200
Old 02-24-2009, 10:13 PM
right, right... I know, I went with the 26918 spring on my set of vortecs but only because I'm running a solid and my 327 sees 7K pretty regularly so the springs were worth it in my case- or now that I think about it maybe not? Ultimatley, do what's cost effective, which I'm sure you are.
Old 02-24-2009, 10:37 PM
i will be using it as a daily but i also want it to be strong... what im most afraid of is the performance from normal springs... will they be as good as beehive?? and what not.. i think down the road the only difference will be maybe 30-50$ from machined head to beehive springs... but i got time so i will think it thoroughly...
Old 03-10-2009, 07:54 PM
did u have to do any machining... i was reading that vortecs guides are .900 diameter so i would need a spring that has a larger inside diameter of .900 and the 26918 or 26915 have .885... wondering if that will cause any probs???
Old 03-11-2009, 08:54 PM
the 918's cleared fine... no machining at all.
Building blown 355 motor ssmonte Engine 5 11-29-2005 05:15 PM
Thinking about building a purpose built nitrous motor! Please critique leemoses Engine 22 06-19-2005 09:15 PM
Building Lift kit. D200Dodge Suspension - Brakes - Steering 10 01-18-2005 03:08 AM
Finally started building 355 Gettheledout Engine 1 11-14-2004 06:27 PM
which one to turbocharge 355 or 400 TerroRx7 Engine 11 10-13-2004 05:45 PM
