Building a 355 - Page 4 - Hot Rod Forum : Hotrodders Bulletin Board
  #46 (permalink)
Old 02-14-2013, 06:09 PM
Banned
Originally Posted by tcmcgrath View Post
Well the cam that comes with it is an edelbrock performer rpm cam with 308/318 duration and a light of 488/510 with a matching intake and an edelbrock 750 cfm carb plus those heads you suggested
I MAY use an Edelbrock cam if it was free, but I sure as hell wouldn't pay for one. You can do a lot better than that cam choice.
  #47 (permalink)
Old 02-14-2013, 06:27 PM
Well for the 1500 to 6500 range what kind of cam should I be getting then for that kind of money?
  #48 (permalink)
Old 02-14-2013, 06:48 PM
building a 355
This mechanical roller cam would go with the Dart SHP 180 top end kit. Howards Cams Steel Billet Mechanical Roller Camshafts 110183-10 - SummitRacing.com. You would also need a 3000 stall converter. Call Howards to check on the best lifters and valve springs as a kit.
  #49 (permalink)
Old 02-14-2013, 07:05 PM
I'm going with the jegs heads
  #50 (permalink)
Old 02-14-2013, 08:21 PM
vinniekq2's Avatar
CD,good choice
howards has a few cams like that with the ICL and LDA moved around a little.Good cam for a serious motor
  #51 (permalink)
Old 02-15-2013, 08:57 AM
Banned
what is your stall, gears, tire size, compression, carb size, and exhaust?
Also, do you want a nice easy driving cam or a more rowdy "almost race" type cam?
Are you concerned more with stop lights and cruising or track times?
What is your budget?
  #52 (permalink)
Old 02-15-2013, 10:51 AM
I already purchased that kit I linked and it comes with the performer rpm intake and cam and a 750 cfm carb. I'm just trying to be quick light to light is all so I'm hoping that will be more than enough. I don't need to be the fastest car on the street I just also don't want to be thought of as slow either.
  #53 (permalink)
Old 02-15-2013, 11:16 AM
Banned
If you're going to run that cam and the springs that you get can handle it I would run all the rocker ratio you can on the intake, that's a pretty low lift for that duration and could use some help.
Maybe see if you can get a 1.65/1.5 split set of rockers when you buy them.
  #54 (permalink)
Old 02-15-2013, 11:36 AM
With that setup what would you suggest as an alternative cam?
  #55 (permalink)
Old 02-15-2013, 11:58 AM
Banned
If you have it, then you may as well run it, but for the money there are better options.
I would have gone with a little less duration, a little more lift, and a lot less seat duration. I will say though that such a mild cam will be very easy on valvetrain parts.
  #56 (permalink)
Old 02-15-2013, 12:00 PM
As far as performance though am I going to be doing alright? I mean I know I won't be running 11s but I am hoping it's pretty quick
  #57 (permalink)
Old 02-15-2013, 12:04 PM
Banned
you'll be pretty quick, still over 400hp if you have a good exhaust. Those Jegs heads are about the best deal currently going and with the RPM intake you got really open up a lot of performance. Just don't choke it with a bad exhaust and make sure to have your ignition and carb tuned by someone who REALLY KNOWS WHAT THEY'RE DOING. Edelbrock carbs are pretty simple but a lot of people still screw them up.
  #58 (permalink)
Old 02-15-2013, 12:33 PM
What kind of exhaust do you suggest? I have hooker headers on it but not sure about the mufflers as the exhaust came with the car
  #59 (permalink)
Old 02-15-2013, 01:12 PM
Banned
what hooker headers? Single or dual exhaust? Does sound matter? what kind of sound do you want? Is power your main concern or second to sound? budget?
  #60 (permalink)
Old 02-15-2013, 02:29 PM
Dual exhaust and although I'd like it loud I would rather have power or a happy medium if possible
building a 355 SBC CodyC10Kid Engine 0 12-27-2009 08:41 PM
building a 355 abas_abas Engine 14 03-18-2009 10:45 AM
New guy,building a 355 ssj3Jon Engine 5 02-14-2007 06:45 PM
Building blown 355 motor ssmonte Engine 5 11-29-2005 06:15 PM
Finally started building 355 Gettheledout Engine 1 11-14-2004 07:27 PM
