building a 383. - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-24-2007, 07:38 PM
building a 383.
I wanted to ask people their opinion on what kind of combos i should run cause i got the 383 stroker block and the whole interior of the motor is complete and i was planning on supercharging it but i need to know what kind of carb is the best to run, what kind of distributer, what kind of stall speed i should run on my converter, and anything else i that will help the performance of my supercharged motor. all the help is greatly appericated thanks.
Old 07-24-2007, 07:51 PM
dinger's Avatar
I'm going to send this over to the engine section, lots of help there. Dan
Old 07-25-2007, 02:23 AM
techinspector1's Avatar
Wiki Edits: 326
Gonna need more info. What vehicle will be the recipient of this motor? How much will the vehicle weigh? What's the static compression ratio of the motor? What cam is in the motor? What's the rear gear?
It would be simple to say that you will need two 500's on a Jimmy, but we don't even know the type of blower you are considering.
new and need help building 383 stroker enygma500 Engine 10 02-10-2013 02:24 PM
Look for info an building a 383 stroker Cllmewish Hotrodding Basics 16 12-28-2012 04:31 AM
Building a 383 stroker holstonallen Engine 3 06-04-2007 10:55 PM
building a 383. what cylinder heads? Troll_Killer Engine 26 11-27-2004 08:32 PM
What kind of power can I bolt on to my 1965 stock 383? Dizturbed One Engine 3 10-07-2004 01:09 PM
