Building a 383 stroker - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-31-2007, 03:47 PM
What is the best cam to buy. I would also like to buy aluminum heads but I am worried about heat. Would powder coating help keep things cool, such as an engine block and exhaust manifolds? Thanks
Old 05-31-2007, 09:21 PM
327NUT's Avatar
We need a lot more info on your buildup, compression, intake and carb etc.... and what type of car, trans, rear end gears. Basically everything you can think of to give you a cam suggestion. As far as the aluminum heads its a mute point, they won't get any hotter that iron heads but they will cool down faster. And you wouldn't want to powder coat them or the exhaust, only use thermal or ceramic coating on the headers, its works very well to keep the heat down.
Old 06-01-2007, 03:00 PM
techinspector1's Avatar
Wiki Edits: 326
Here are over 100 dyno-proven SBC engine combinations. Pay particular attention to combos 11, 15, 16 and 17.....11 makes 470 ft/lbs of torque at 3,500 rpm's and would make a great street motor on pump gas. Just use the same components listed in the build and assemble carefully, using a squish of 0.035" to 0.040".
http://www.ryanscarpage.50megs.com/combos2.html
Old 06-04-2007, 09:55 PM
383silverado's Avatar
383 539 horsepower on pump gas
539 hp
523 tq
http://compcams.com/Community/Articl...p?ID=626740338
Look for info an building a 383 stroker Cllmewish Hotrodding Basics 16 12-28-2012 03:31 AM
383 stroker deiseling when I try to shut er down tdhixon Engine 6 09-27-2007 12:31 AM
Thanks for the 383 Stroker info Ron Mexico Introduce Yourself 2 01-11-2006 11:05 AM
SB Chevy Balanced 383 Stroker Kit from CNC-Motorsports.com bccsrc Engine 19 01-04-2006 06:51 AM
HEI or full MSD on 383 Stroker? my350camaro84 Electrical 5 02-07-2005 08:04 PM
