Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Building a 383 stroker
Old 05-31-2007, 09:21 PM
327NUT's Avatar
327NUT 327NUT is offline
We need a lot more info on your buildup, compression, intake and carb etc.... and what type of car, trans, rear end gears. Basically everything you can think of to give you a cam suggestion. As far as the aluminum heads its a mute point, they won't get any hotter that iron heads but they will cool down faster. And you wouldn't want to powder coat them or the exhaust, only use thermal or ceramic coating on the headers, its works very well to keep the heat down.
