Building 383 stroker, Any Tips or Tricks - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-25-2007, 04:55 PM
I'm building a sbc 383 stroker. I have had the my vortec heads cut out to a 2.02 intake,1.60 exhaust. I have Eagle cast stroker crank and Forged 6'' rods. To go with the build. What pistons would you recommend . Thinking about the Keith Black signature series Hypertetic pistons. Also what rings
Old 01-25-2007, 05:17 PM
techinspector1's Avatar
Wiki Edits: 326
First you have to determine the operating range of the motor and what you want it to do for you. That will determine the cam and the cam will determine the compression ratio and the compression ratio will determine the pistons.
Old 01-25-2007, 05:22 PM
I'm looking at 1500,-5500 rpm range. also going into a camaro 1991 rs.
Hoping for 400-450+hp.
Old 01-25-2007, 06:13 PM
Wiki Edits: 326
Take a look through these dyno-proven combinations of small block Chevies. There are over 100 of them. Just go through and pick out the 383 combos that make the most torque at the lowest rpm. You'll need torque with that heavy car, not horsepower and particularly limiting the motor to 5,500. Pay particular attention to the power difference between OEM GM heads and aftermarket heads. If you really want to wow the troops, spring for a set of AFR heads and follow the recipe in any of the 11 to 17 combos. I like combo 11 with max torque being produced at 3,500 rpm's.
http://www.ryanscarpage.50megs.com/combos1.html
383 Stroker question Houman SS '70 Engine 60 10-30-2009 07:46 AM
383 stroker deiseling when I try to shut er down tdhixon Engine 6 09-27-2007 12:31 AM
383 Stroker Beowulf Engine 2 07-14-2006 07:08 AM
383 stroker kit (Ebay) Hazard Engine 8 05-24-2006 06:51 AM
SB Chevy Balanced 383 Stroker Kit from CNC-Motorsports.com bccsrc Engine 19 01-04-2006 06:51 AM
