building 388 stroker what can i do to get the most power of of it?
i pulled an old 350 out of my 92 chevrolet silver ado and i planned on building it into a 383 stroker, it had already been bored .040 over but when i sent it off to the machine shop they bored it .060 over, so i now plan on building a 388 what heads crankshaft, cams etc.. should i put in it to get the most horsepower out of it but still be able to drive it as a "sunday driver"
How much horsepower and what's your budget? Are you willing to modify your drive train if needed? Tell us more about what you want.
Horsepower is how fast you hit the wall. Torque is how far you take the wall with you. Midnight Sun Street Rod Association |
it is going into my 4wd truck, i want roughly around 400 hp if not more i would like t modify it as less as possible and will spend whatever i have to to get the most out of this engine
I put a small supercharger on my K5 Blazer and loved it. It helped move that 4500 lb truck around very well. The best part was that it even fit under the hood.
Could I get around 500 hp out of it with roughly no problems?
Yes, 500hp is possible but it wil not be as streetable as you may like. In a big 4 wheel truck torque is your best friend. I would reccomend AFR 190 heads, long tube headers with 1 5/8" primaries. Then call Comp or one of the other major cam manufacturers tech lines and tell them your setup. You are going to want a cam that will build torque fast and hold the torque steady through the entire power band. No need for 500hp @ 6200 rpm if you never get there, but 600 lb. ft. of torque wil put a big smile on your face.
600 lb ft torque would be amazing, im rebuilding my dads 92 chevrolet silverado he passed away in 07, and in the 90s whi.got real big into drag racing he had a couple nice camaros and a sick chevelle all with big block engines, so I figured since I got his truck after he passed away as my very first truck I would completly restore it but add a lil exra something to it, this is the firstbproject I have ever done on my own I would occasionally work on the cars out in the garage with him on the cars, but I want to.build his truck up nice to where its a real attention getter, ive always loved real big engines with alot of power, basicly I just wonna have a real bad toy thats is fun to drive
If you want 600 lb-ft of torque in a 4x4 pickup then you should start looking at ~06-up 3/4 ton diesel trucks. You're going to be in your truck about the same after spending money on the engine and the rest of the drivetrain as you would buying one of the newer diesel trucks. Otherwise, be realistic about your goals here.
| new and need help building 383 stroker | enygma500 | Engine | 10 | 02-10-2013 01:24 PM |
| help with building a 377 stroker | shartstainedbvds82 | Engine | 20 | 07-02-2008 03:19 AM |
| Building a 383 stroker | holstonallen | Engine | 3 | 06-04-2007 09:55 PM |
| Building a 383 stroker | jchav62 | Engine | 9 | 12-15-2005 08:28 PM |
| building a 383 stroker | johny500 | Engine | 2 | 12-14-2003 08:39 PM |
