Good ckoice i recently built a 1953 chevy pu i am running a .30 over 454 block flat top pistons, pro comp aluminum heads, comp cam 268h and roller rockers a 69corvette tri power carbs and intake sanderson cast iron headers tube headers or factory manifolds would not fit i have driven a little very streetable with turbo 400 331 gears b&m 2400 converter i probably get comments on pro comp heads I tried to post pictures but dont know how i have a 85 monte carlo ss frame clip with power sterring disc brakes 10 bolt probable the weak link 295/60/15 rear tires on 11 inch wheels and yes traction IS a problem you can use stock rear springs changed mine to mono no difference hope this helps on your project
